I'd like to live like a poor man
... only with lots of money.
Today's Birthdays
1965BB, ONTMODELTCHEV
Featured Chat Guy (or Gal)
728
728
VCCA Member Photos
Getting ready for the 4th of July Parade
Interesting Delivery
32' Oldsmobile Dovetail Receptacle
32 Special Bracket ID
Chevrolet Trim Plate
Pilot Bushing Removal Tool artile
VCCA Member Projects
53rd installment - '28 engine tear down
52nd installment - '28 engine tear down
51st installment - '28 engine tear down
50th installment - '28 engine tear down
49th installment - '28 engine tear down
Topic Options
Rate This Topic
#391209 - 06/24/17 11:56 PM Chrome Plating Problem
Hawkeye Offline
Loc: Ohio
I had my rear quarter window frame chrome plated and it turned out great. Just one problem, now the pivot arm that connects to the assembly will not turn. I tried Blaster but it is still not moving. I do not want to pry to much because it is pot metal. Any suggestions?
Top
#391215 - 06/25/17 01:37 AM Re: Chrome Plating Problem [Re: Hawkeye]
Junkyard Dog Offline
Loc: Eagle Point, Oregon
The pivot arm will not turn because of the plating buildup between the frame and the pivot arm. The pivot arm might have to be removed so that the excess plating can be removed to give the pivot arm room to turn.
_________________________
Top
#391239 - 06/25/17 07:36 PM Re: Chrome Plating Problem [Re: Hawkeye]
blue38 Offline
pumpjockey
Loc: phoenix......az
Same problem once..I used propane torch with mild heat and the contact area moved with no damage to new chrome.
Top
#391505 - 06/30/17 02:05 AM Re: Chrome Plating Problem [Re: blue38]
Hawkeye Offline
Loc: Ohio
Both great suggestions. I heated up the pin area with a heat gun. Had my wife hold the frame so I could hit the pin with a punch. I did cut a notch in a 1/4" piece of wood so I could place it where the glass would have been for support. After several gentle wacks with a small hammer, the pin began to move. I removed the pin, cleaned up all the areas that came into contact with the pivot arm, put a little silicone gel on all the contact points and put it back together. Attached is a photo of what tools I used. Thanks for the suggestions JunkYardDogJunkYardDog and blue38. No fingers or chome were harmed in this event.
Top
#391509 - 06/30/17 02:22 AM Re: Chrome Plating Problem [Re: Hawkeye]
Good going and glad that you were able to resolve the problem.
Usually, in situations like that the pin and pivot arm are removed first before plating, then both the frame and the pivot arm are plated. The pin is cleaned and polished and is then reinserted joining both pieces back together.
Top
#391548 - 06/30/17 10:45 PM Re: Chrome Plating Problem [Re: Junkyard Dog]
Hawkeye Offline
Loc: Ohio
Never had anything like this chrome plated before. The first question I had for the platter when I gave this piece was, should I remove the pivot arm. He said it will be okay and to leave it on. Life lesson # 3,018 - only 2,781 to go.
Top
#391563 - 07/01/17 06:40 AM Re: Chrome Plating Problem [Re: Hawkeye]
The fellow at the plating shop was incorrect. Parts should be completely disassembled before plating when possible.
Top
Moderator:  AntiqueMechanic
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
0 Chat Members (), 1 Guest and 28 Spiders or Bots online.
Key: Admin, Global Mod, Mod
We speak Chevy!
Time Flys!
Since 12/16/2001
Previous Photos
Newest Chat Registration
Emanuel, DrDoug, ronp, ChevyNC, 5pcoupe
14739 Registered Users
VCCA Info Links
NEWBIES START HERE
CHAT HELP
Send My Password
Kill My Chat Cookies
VCCA Home
G&D Calendar
Judging
Club Regions
Join Info
Forum Stats
14739 Chat Users
77 Forums
48874 Topics
Max Online: 304 @ 06/18/16 10:00 AM
See the USA
In your
Dinah says Hi!!
