Posts: 1,019 Likes: 3
Posts: 1,019 Likes: 3 |
Hello Everyone, I'm installing a glove box mounted clock in my '37 MD. I figured out which wires connect where as the original harness (what was left of it) was separate of the clock. (Using new wire to make all the connections) My questions are.... is the power wire connected to the live side of the ignition switch, and should there be an inline fuse and what amp should that be ?? If there is a diagram available, that would be great to have a copy of it.
Posts: 30,700 Likes: 141
Posts: 30,700 Likes: 141 |
Is it a spring wound clock or an eletric clock?
Hello Chevgene, This is an electric clock..3 wires...clock power , ground and light power.
Posts: 29,848 |
From the 1939 clock written instructions. Red clock wire goes to light switch battery terminal.This will provide the clock with constant power
Black wire to the light switch terminal for the tail lights. This will light the clock bulb any time the head lights were turned on.
White wire is gronud and attached to a screw in the metal of the dash.
2 members (chevy b, ruscar),
76
guests, and
21
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,071
Posts429,077
Members18,308
