Entire store on sale
... Everything $1 or more.
Today's Birthdays
Bengt Johansson
Featured Chat Guy (or Gal)
VCCA Member Photos
Getting ready for the 4th of July Parade
Interesting Delivery
32' Oldsmobile Dovetail Receptacle
32 Special Bracket ID
Chevrolet Trim Plate
Pilot Bushing Removal Tool artile
VCCA Member Projects
53rd installment - '28 engine tear down
52nd installment - '28 engine tear down
51st installment - '28 engine tear down
50th installment - '28 engine tear down
49th installment - '28 engine tear down
Topic Options
Rate This Topic
#390817 - 06/16/17 06:47 PM Gearbox making some trouble.
Solan Offline
Loc: Oslo, Norway
The gear box of my 1916 is working fine except for going out of grip when climbing hills in 2nd gears. To avoid that I need to hold the gear shifter from changing position and a possible break down thereafter.
Would the gearboxes to 490 passenger cars be the same size/construction from late 1915 to 1922? I would think so, but do not know for sure. Would it be possible to make the part(s) in trouble instead of changing the whole unit? Do I have to remove the box anyway to mend it?
Thanks for any help. I have some pictures of a spare one which may be used, and the one in my car to show, to send in a PM.
parking
_________________________
Solan G, # 32797
Top
#391034 - 06/21/17 07:57 AM Re: Gearbox making some trouble. [Re: Solan]
jack39rdstr Offline
Loc: Australia
Many of the 4 cylinder gearbox gears will fit into your case. Up to 1923 , all should fit into your 1916 case . The top selector mechanism is different.
1924 onwards the clutch Gear (input gear) is different as the clutch changed from the cone clutch to the disc clutch and pressure plate design.
The gears are probably easier to find in a second had gearbox than NOS / NORS gears. Failing that, the gears can be copied by a competent gear cutting firm as they are all straight cut.
Yes remove the gearbox.You will have to disassemble the gearbox and inspect all the gears for worn teeth, and then replace them or have them copied.
JACK
Top
Moderator:  AntiqueMechanic, Bob_Kerr
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
0 Chat Members (), 2 Lookie Loo's and 4 Spiders or Bots online.
Key: Admin, Global Mod, Mod
We speak Chevy!
Time Flys!
Since 12/16/2001
Previous Photos
Newest Chat Registration
Emanuel, DrDoug, ronp, ChevyNC, 5pcoupe
14739 Registered Users
VCCA Info Links
NEWBIES START HERE
CHAT HELP
Send My Password
Kill My Chat Cookies
VCCA Home
G&D Calendar
Judging
Club Regions
Join Info
Forum Stats
14739 Chat Users
77 Forums
48871 Topics
Max Online: 304 @ 06/18/16 10:00 AM
See the USA
In your
Dinah says Hi!!
