Don't be stupid
... it might make you famous.
Today's Birthdays
Marv
Featured Chat Guy (or Gal)
VCCA Member Photos
Getting ready for the 4th of July Parade
Interesting Delivery
32' Oldsmobile Dovetail Receptacle
32 Special Bracket ID
Chevrolet Trim Plate
Pilot Bushing Removal Tool artile
VCCA Member Projects
53rd installment - '28 engine tear down
52nd installment - '28 engine tear down
51st installment - '28 engine tear down
50th installment - '28 engine tear down
49th installment - '28 engine tear down
Topic Options
Rate This Topic
#390932 - 06/19/17 01:02 PM 1941 fuel pump leak
MoonshineMachine Offline
Loc: Eastern NC
So after 8 months of mechanical restoration, I drove my 1941 Master Deluxe for the third time ever, and first time in a long time. I put about 80 miles on it, and then brought it home to investigate all of the gremlins.
I have oil seepage around the fuel pump. I had replaced the gasket and I'm not sure if the gasket is the issue or if it is possibly leaking from the pump itself. It almost appears to be leaking from the lower pin that holds the lever on the inside. Do these fail internally and leak oil to the outside? It is possible that for whatever reason I didn't get a good seal on the install, but I may order a new pump depending on responses here.
I did use permatex on the bolt threads and I used Indian Head gasket sealer on the gasket install (let both sides get tacky prior to install).
Top
#390934 - 06/19/17 01:25 PM Re: 1941 fuel pump leak [Re: MoonshineMachine]
Chev Nut Offline
Loc: West Allis,Wi.
tHE "PIN" LOCATION IS A COMMON PLACE FOR THE OIL TO LEAK FROM. I HAVE HAD SEVERAL DO THAT FOR ME ON MY CARS. tHROUGH THE YEARS THERE WERE SEVERAL DIFFEENT WAYS THE AREA WAS SEALD AND ALL TEND TO LEAK AT SOME TIME OR ANOTHER.
Time to purchase a new pump> sorry about the caps willy
Edited by Chev Nut (06/19/17 01:26 PM)
_________________________
Chevgene
Top
#390942 - 06/19/17 02:45 PM Re: 1941 fuel pump leak [Re: Chev Nut]
Loc: Eastern NC
Well that confirms my suspicion. Time to place an order.
Top
#390945 - 06/19/17 02:54 PM Re: 1941 fuel pump leak [Re: MoonshineMachine]
Chev Nut Offline
Loc: West Allis,Wi.
iagree
Chevgene
Top
#390989 - 06/20/17 06:06 AM Re: 1941 fuel pump leak [Re: MoonshineMachine]
Mark Yeamans Offline
Loc: Reno, NV
If your fuel pump is working well except for the oil leakage at the pivot pin, you can get away with a temporary fix as follows:
Remove the leaking pump and thoroughly clean both sides of the pump body where the pivot pin passes through, using acetone or some other suitable cleaner, then put a dab of hi-temp black silicone over each end of the pin where it exits the pump body, making sure the silicone is in full contact with both the pin and the pump body. For best results, allow the silicone to cure for 24 hours before putting the pump back in service. This repair has lasted several thousand miles on my 37 1/2 ton pickup. It's also a good time to consider replacing the two hex head bolts that hold the pump to the block with two socket head bolts due to poor wrench clearance on the hex head bolts.
Mark
Top
Moderator:  ken48
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
0 Chat Members (), 0 Lookie Loo's and 40 Spiders or Bots online.
Key: Admin, Global Mod, Mod
We speak Chevy!
Time Flys!
Since 12/16/2001
Previous Photos
Newest Chat Registration
Shermy, CommanderSashi, Emanuel, DrDoug, ronp
14741 Registered Users
VCCA Info Links
NEWBIES START HERE
CHAT HELP
Send My Password
Kill My Chat Cookies
VCCA Home
G&D Calendar
Judging
Club Regions
Join Info
Forum Stats
14741 Chat Users
77 Forums
48874 Topics
Max Online: 304 @ 06/18/16 10:00 AM
See the USA
In your
Dinah says Hi!!
