Posts: 812 Likes: 13
Posts: 812 Likes: 13 |
I have a 1922 FB (Olds) 3 port head. Where does the hole between the intake ports go? (Please Email me for photo.) Thank you, Lou.
Posts: 1,213 |
The hole in between the 2 intake ports on the head feeds hot exhaust gasses to the "hot box" that surrounds the intake manifold riser to heat up the air/fuel mixture.If you remove the cast iron cover plate,you'll see where the exhaust gasses will have passed around the vertical riser. The inlet manifold "hot box" cover on an Olds 3 port head will have the Oldsmobile script cast on the outside of it,the FB inlet cover plate may be just a plain cover plate,no script cast into it.
CJP'S 29
Posts: 3,511 Likes: 47
Posts: 3,511 Likes: 47 |
If you need some OLDS 3-port head parts, Mark Garcia in Fremont has a few.
