Posts: 23 |
Hello I am looking for the best repair kit for a 1949 684s Carter W1 It is very important to me to have clear instructions like where the seals are going for example Could somebody tell me where I could order such a kit ? Thank you Best regards JC
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
The best kit would be a Carter factory rebuild kit No. 1500A. They are occasionally listed on eBay and have an instruction sheet included as well as the most often needed parts. Expect to have to soak some gaskets to make them supple again. An alternate would be a modern kit some come with instruction sheets.
Posts: 23 |
Thank you for your answer. But can somebody tell me where to buy a full modern kit with detailed instructions ? Thank you Best regards JC
Posts: 1,896 Likes: 28
Posts: 1,896 Likes: 28 |
These are the best I have found; www.thecarburetorshop.com
Jon has not only the kits but also tons of knowledge on carburetors. Willing to share occasionally on Chat and on the phone.
Posts: 23 |
Thank you all, I will call Jon at the www.thecarburetorshop.comBest regards JC
