I know, I know, many of you don't like the Pertronix - this is not another discussion topic about "to use or not to use". I do like them and have had good luck with them in the past.
My issue, is that I'm having difficulty figuring out how to wire it in on my 1941 Chevy (original components, 6V, and 216 in the car). The wiring instructions from Pertronix show where the wires from that unit go (to the coil, red +, black -) but I cant figure out where the wiring from the starter reversing switch goes. I have 3 wires from that unit. My new wiring harness shows that one wire goes to the negative side of the coil, easy enough. The other two wires have me confused. Those two wires originally would have gone to the terminals on the outside of the distributor (one to the breaker and one to the condenser) but now those aren't attached to anything in the housing.
Any suggestions?
