Vintage Chevrolet Club Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
VISITORS: You are welcome to read our forums. If you want to participate FREE then you need to register. Join the VCCA and get access to the member-only features of the forum, including the ability to attach/upload photos. You'll also receive our monthly magazine "Generator & Distributor". Yearly membership as low as $25!
VCCA MEMBERS: Already a member? Great! Info to access the members-only area.
Topic Options
Rate This Topic
#390482 - 06/08/17 01:03 PM Pertronix Install
MoonshineMachine Offline
Loc: Eastern NC
I know, I know, many of you don't like the Pertronix - this is not another discussion topic about "to use or not to use". I do like them and have had good luck with them in the past.
My issue, is that I'm having difficulty figuring out how to wire it in on my 1941 Chevy (original components, 6V, and 216 in the car). The wiring instructions from Pertronix show where the wires from that unit go (to the coil, red +, black -) but I cant figure out where the wiring from the starter reversing switch goes. I have 3 wires from that unit. My new wiring harness shows that one wire goes to the negative side of the coil, easy enough. The other two wires have me confused. Those two wires originally would have gone to the terminals on the outside of the distributor (one to the breaker and one to the condenser) but now those aren't attached to anything in the housing.
Any suggestions?
Top
Vintage Auto Garage - 6 Volt
#390495 - 06/08/17 11:31 PM Re: Pertronix Install [Re: MoonshineMachine]
dens41 Offline
Loc: iowa
I would think that you need to wire it without the reversing switch. You will have to run a ground wire to the post near the side cover, that's the I have grounded on my 47. Then wire the - side of the coil to the other post. I hope this helps.
Denny
_________________________
Dens Chevys 1928 coupe 1941street rod 1947Fleetline 4 door 1949 1/2 ton Pickup 1954 210 4 door 1972 Monte Carlo 2003 Corvette convt..
Top
#390518 - 06/09/17 01:20 PM Re: Pertronix Install [Re: dens41]
Loc: Eastern NC
I suppose I didn't even really know what the reversing switch did. After your comment, I did some further searches for the reversing switch and think that your solution is dead on. Now that I understand what the switch was designed to do, I don't think I need it wired to anything anymore.
Thank You
Top
#390537 - 06/09/17 11:58 PM Re: Pertronix Install [Re: MoonshineMachine]
Chev Nut Offline
Loc: West Allis,Wi.
If the reversing switch has been removed or disconnected it would be necessary to do the following. The terminal closest to the engine should be grounded to the engine. (the terminal directly accross from the outter terminal) The terminal towards the outaide is the connected to the coil.
Chevgene
Top
#392693 - 07/24/17 08:10 PM Re: Pertronix Install [Re: Chev Nut]
41specialdeluxe Offline
Loc: NC usa
iagree
Just remember, Gene is talking about the Distributor here.
Edited by 41specialdeluxe (07/24/17 08:10 PM)
Top
Moderator:  AntiqueMechanic, Coupefan
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
1 Chat Members (Peter_Gariepy), 1 Guest and 28 Spiders or Bots online.
Key: Admin, Global Mod, Mod
Today's Birthdays
32confederate
Helpful Links
Forum Registration
New User Forum
Members Only Forum
Reset Your Password
Kill Your Cookies
VCCA Home
Join the VCCA
Member Photos
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
1936 Roadster - S. Africa
Chevy on the Levee
'37 Seat
Forum Stats
15086 Chat Users
79 Forums
50178 Topics
Max Online: 304 @ 06/18/16 10:00 AM
