Posts: 1,441 |
I had over a quarter of a tank of gas evaporate from my 37 over the winter so I presume the vent is constantly open and todays gas is probably more to blame.
VCCA #45194
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I know gas does evaporate but during the cooler times at a slower rate. A 1/4 tank seems to be a very high quantity for very warm temps though so I would suspect there may be a small leak contributing to the issue. Tony
Posts: 1,441 |
No leaks that could be found.
VCCA #45194
Posts: 1,894 |
Be difficult for that much gas to evaporate through a pin hole in the cap. If there was a leak I'd think you'd likely smell it and see residue/staining as the loss would be a few gallons.
Maybe the gauge isn't reading correctly now or when put away in the fall? Maybe the sending unit is a bit worn right around that particular level so in the fall it read high and then after sitting it made a better connection and read low. Maybe the ground to the sending unit developed a bad connection over the winter?
Ethanol in the fuel can mess with the cork floats if they are original so maybe the floats are fuel logged?
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
A 1937 pickup does not vent through a pinhole in the cap. There is a 1/4 (or so) vent tube that lets fumes from the top of the tank exit the cab through the floor pan under the tank. It is a one year only arrangement, as far as I know. All that being said, 1/4 tank is lots of fuel to lose in cold weather.
Posts: 318 |
Speaking of gas tanks, mine has been inactive for awhile while I am doing some work on the truck and I also have lost gas from my 37. It prompted me to put some Stable in the tank and now the fuel line to the fuel pump is blocked. I may have to pull the tank to clean it. Something I have never done.
See Facebook Page for Joe Fuchs to see more pictures of my 1937 Chevrolet 1/2 Ton Pickup
