Posts: 2 |
I am wanting to upgrade my 1952 Chevrolet engine from a 216 to a 235> I found a 235 from a 1955 Chevy. Will this swap work as far as motor mounts$ I know the transmission will need to be changed as well as the third member.
Posts: 30,700 Likes: 141
Posts: 30,700 Likes: 141 |
The problem is ataching your 1952 side motor mount brakets to the 1955 engine. A 1953-54 engine would be a direct fit including the water pump not needing changes. There would be no need to change the bell housing or transmission but if youkeep the 6 volts the 1952 fly wheel and starter wold need to be used..
Posts: 2 |
Thanks, this answers a lot of my questions.
Posts: 3,511 Likes: 47
Posts: 3,511 Likes: 47 |
Here's an article that pertains to your questions: http://www.stovebolt.com/techtips/engine_swap_216.htm Cheers, Dean
2 members (chevy b, ruscar),
76
guests, and
21
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,071
Posts429,077
Members18,308
