Jean Offline OP
Hello
I am looking for the best repair kit for a 1949 684s Carter W1
It is very important to me to have clear instructions like where the seals are going for example
Could somebody tell me where I could order such a kit ?
Thank you
Best regards
JC
The best kit would be a Carter factory rebuild kit No. 1500A. They are occasionally listed on eBay and have an instruction sheet included as well as the most often needed parts. Expect to have to soak some gaskets to make them supple again. An alternate would be a modern kit some come with instruction sheets.
Jean Offline OP
Thank you for your answer.
But can somebody tell me where to buy a full modern kit with detailed instructions ?
Thank you
Best regards
JC
These are the best I have found;
www.thecarburetorshop.com
iagree Jon has not only the kits but also tons of knowledge on carburetors. Willing to share occasionally on Chat and on the phone.
I also agree!
Jean Offline OP
Thank you all,
I will call Jon at the www.thecarburetorshop.com
Best regards
JC
