#389846 05/26/17 04:21 PM
mcvaca Offline OP
I have a 1964 ss convert impala colors white and aqua with factory AC cruz pw breaks pw windows 327 with auto trans tilt steer power roof is this a rare one it was orderd in OK city built in vannuys CA i found the biuld sheet under the dash pad thanks for any info on this
Wilwood Engineering1955-1957
The more options - - the rarer it is. Post a pic of the build sheet.
Verne
The cruise controll will not be on the build sheet as it was available as a dealer installed accessory only.
mcvaca Offline OP
im not sure then the build sheet I have i dont understand most of it is what i think are part numbers i was told that it was a build sheet when i found it under the dash pad by the speaker
Different plants used different styles of build sheets (Broadcast Copies), but they don't list part numbers. If you can post a photo of it, I can try to decipher it for you.
Verne
mcvaca Offline OP
ok trying to find it my ex "the [bleeped]" made a lot of stuff disappear
