If your wife wants to learn to drive,
... don't stand in her way.
Today's Birthdays
32confederate, EdLo, ewv715, galen33, Paul Boyd
Featured Chat Guy (or Gal)
VCCA Member Photos
Getting ready for the 4th of July Parade
Interesting Delivery
32' Oldsmobile Dovetail Receptacle
32 Special Bracket ID
Chevrolet Trim Plate
Pilot Bushing Removal Tool artile
VCCA Member Projects
53rd installment - '28 engine tear down
52nd installment - '28 engine tear down
51st installment - '28 engine tear down
50th installment - '28 engine tear down
49th installment - '28 engine tear down
Topic Options
Rate This Topic
#389685 - 05/23/17 08:42 PM Sealants and fillers
OldRadioTech Offline
Loc: Alaska
Putting re-manufactured heads on a 283. Felpro gasket kit says for those headbolts entering the coolant passages apply a pliable non-hardening sealer to the threads. Recommendations?
Instructions also say to apply a quick drying adhesive to the cylinder heads to hold the intake manifold gasket in place. Recommendations?
Lastly, I have some pitting on the block at the head mounting surface around the coolant passages/water jacket holes. Looking to fill these areas to improve the chances my head gasket will remain sealed. Recommended fillers?
Thanks,
Paul
Top
#389690 - 05/23/17 09:45 PM Re: Sealants and fillers [Re: OldRadioTech]
Chev Nut Offline
Loc: West Allis,Wi.
The shop manual says clean out bolt thread holes and cylinder head bolt threads (a thread chaser works well).
coat all head bolt threads with a special sealing compound such as Permatex #3.
I would use the same product on the pits...a very thin coat.
If it were mine I would use nothing on the intake gaskets, especially the rubber ends as some adhesives cause the rubber end gaskets to squirm out of place. I just position them carefully watch to see that they remain in place.
_________________________
Chevgene
Top
#389732 - 05/24/17 06:01 PM Re: Sealants and fillers [Re: Chev Nut]
Loc: Alaska
Chevgene - what are your views on using or not using the rubber end gaskets
Top
#389776 - 05/25/17 02:25 PM Re: Sealants and fillers [Re: OldRadioTech]
chevy1937 Offline
pumpjockey
Loc: Hubbard,Ohio
I always used them. Put on dry and a small amount of sealant in corners.
Top
#389778 - 05/25/17 02:49 PM Re: Sealants and fillers [Re: OldRadioTech]
Chev Nut Offline
Loc: West Allis,Wi.
I never use a material to hold the end rubbers in place. Even 3M weaterstrip adhesive. While they may hold the rubber in place after the manifold is installed the "glue" allows the rubber to slide out of place. It may hold it from falling off but encourages it to slide.
Chevgene
Top
#389948 - 05/30/17 05:33 AM Re: Sealants and fillers [Re: Chev Nut]
John 348/340HP Offline
1500
Loc: Glen Cove, NY/ Ocala FL
If judging points are not an issue, I would throw those rubber intake valley gaskets in the garbage and use a good bead of silicone in it's place. I have eliminated the rear one on all of my cars and nobody would know, and just use straight silicone
I have always used silicone (as per the Felpro instructions) on the corners of the rubber gaskets, and never had a problem. I also lay a small ring of silicone around the water ports on the intake to head gaskets
John
if you never do nothing, you can never do nothing wrong! (think about it)
1950 2 door Styline Deluxe
1953 2 door 150 Sedan
1975 Cosworth Vega #0718
1977 Monza Mirage 305 4 Speed
1985 Caprice Wagon w/Chevy V-8
1987 Celebrity Wagon
2005 GMC Safari
2013 GMC Sierra 2500 HD Diesel
2015 Cadillac CTS
Top
Moderator:  bowtieollie, John 348/340HP
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
0 Chat Members (), 1 Guest and 36 Spiders or Bots online.
Key: Admin, Global Mod, Mod
We speak Chevy!
Time Flys!
Since 12/16/2001
Previous Photos
Newest Chat Registration
Shermy, CommanderSashi, Emanuel, DrDoug, ronp
14741 Registered Users
VCCA Info Links
NEWBIES START HERE
CHAT HELP
Send My Password
Kill My Chat Cookies
VCCA Home
G&D Calendar
Judging
Club Regions
Join Info
Forum Stats
14741 Chat Users
77 Forums
48874 Topics
Max Online: 304 @ 06/18/16 10:00 AM
See the USA
In your
Dinah says Hi!!
