Posts: 45 |
Does anyone know of an electronic ignition conversion kit for a 1926 superior-v with a 171cu engine?
Posts: 29,847 |
Posts: 45 |
Posts: 19,756 Likes: 62
Posts: 19,756 Likes: 62 |
I had an electronic ignition on a '28 Chevy as a test from a manufacturer. It worked well until a complete failure with absolutely no warning. Luckily the engine was in my shop at the time. I carried a spare points distributor just in case. Installed the points dist and haven't looked back. Those can be fiddled with to get you back home. When the electronics are dead so is your car.
Posts: 6,149 Likes: 41
Posts: 6,149 Likes: 41 |
I have been there, electronic worked well until it died. The modern computer controlled system is an even bigger pain. Tony
Posts: 29,847 |
Posts: 361 Likes: 1
Posts: 361 Likes: 1 |
I am working on a breakerless ignition for 6v 6cylinder applications. My '35 will be tested
Years ago I found a electronic assisted contact system. Basically it was a transistor that controlled by the original points and the transistor switched the coil. It worked well until the points oxidized and werent connecting, only had to rub fine emery paper between the points. The points didnt burn like standard systems as there wasnt the current flow in through them. Tony
Posts: 822 |
Bill, Here's how to do it using GM HEI parts: http://www.hotrod.com/articles/convert-a-ford-or-chrysler-ignition-to-gm-hei/#wiring-diagram-2It can also probably be also done using Mopar components from an electronic distributor. Pertronix and Crane Cams conversions have failed in many applications. The ultra reliable OEM electronic distributor components may not be 100% failure free, but nothing is. Once, decades ago I was driving a company vehicle with point ignition and the point rubbing block broke off leaving me stranded. Nothing is perfect Part of the fun of this hobby is tweaking the sensibilities of the originality purists with "stealth" modifications that make the antiques safer, more pleasant to drive and more reliable. The purists don't care about that because it irrelevant in a show-only trailer queen. .Ray W
Posts: 87 |
I agree with the other comments above.
The electronic ignitions conversions for antique cars work great until they fail and then they are dead, whereas the good old points tend to slowly fade into the sunset and provide warning they need replaced.
On a Triumph website I participate in there have been numerous individuals report failures of the Pertronix units in Triumph TR4s while on the road and they end up needing a tow to get home.
Posts: 822 |
Bill, check this out. http://devestechnet.com/Home/HEIgnitionIt's a conversion a hobbyist can do using a Mopar slant 6 reluctor and a GM HEI module. Those components have been in use on millions of engines for decades and have none of the reliability issues of the aftermarket junk like Pertronix and Allison electronic conversions. Ray W
Posts: 40 |
Here is my take on the Ignition problems, most are experiencing, get rid of the Resistor Spark Plugs, then throw all that resistor wiring away. Rewire and adjust the timing. Yes you might have to make up new wires. Most "old" cars were not in tune with Radio interference, and todays radios and TV's are designed to shield it out. I always had non resistor wiring on my coil, was noticing low power and the cause was resistor plugs and wires. 1954 chev 235 in my 38 pickup that hadn't been run in 30-35 years, it started, slow and hard, it now fires right up no messing around. The wire I obtained from ebay, the plugs I requested a replacement plug non resistor. Do the right thing, save a starter, and your dignity.
7 members (Dogbreath, minetto, Jonjet, Clement, Mr87Monty, Chipper, Dave_in_VA),
71
guests, and
20
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,070
Posts429,052
Members18,308
