#389523 05/21/17 04:21 PM
Having lots of fun driving around town in our' 37 Master Coupe. I have put about 120 miles on it with only a few minor issues.
What are your observations with respect to in-dash ammeter accuracy? Here is the situation I have.
Based on information in some prior posts and the '37 Engineering Specs I wanted to confirm that the generator was providing the right output. When I rebuilt the generator I set the 3rd brush at 2 commutator bars from the main brush.
I was concerned because the dash ammeter was showing 15-16 amps with no lights and over 20 amps with the head light switch in the second position (no resistor). With the lights on it does show a slight plus charge. This car does have a sealed beam 6v headlights and I have put the higher candle power bulbs in the brake and tail lights.
I connected an ammeter directly to the battery side of the cutout on the generator. I was getting about 14 amps with the lights off and about 19 with them on. Remember that the ammeter has already subtracted the ignition and fuel gauge load (about 2-3 amps).
Based on that difference I connected a different ammeter and got readings within 1 amp of the first one. I am also getting about 7.9 volts which I feel is very acceptable.
Should I be concerned with the what seem to be high reading from the in-dash ammeter? Am i getting too much from the generator and running the risk of overheating it?
Thanks for the help.
I would say you have it adjusted as perfect as possible with out better equipment. The generator is designed to put out up to 21 amps or so . Being that the generator is air cooled it can safely put out 21 amps. That how I set the generator on my 1934 using the later air cooled generator with the pulley fan. Never had a problem. While I did not have sealed beams had higher C.P. head and tail light bulbs (dual) and would just be a bit on the + side unless you went over 50 MPH. The 3 brush generator peaks arounr 50 MPH and the charging rate drops after that.
I dont think you have a problem, most automotive instruments are not always spot on accurate. Your readings are very close and within specifications.
tonyw #389578 05/22/17 11:32 AM
Hi Gene and Tony,
Thanks for the confirmation that my readings are in range.
One interesting point and the reason I had to question the ammeter + readings is that the discharger readings seem much more accurate. Those readings all match the calculated loads within about 1 amp.
Gene: Just got my confirmation for the Middle West Meet. It is a shorter time there than I would like but I will be there mid-Wednesday afternoon. See you there!
