Me and my wife lived happily for twenty years....
... then we met.
Today's Birthdays
1965BB, ONTMODELTCHEV
Featured Chat Guy (or Gal)
728
728
VCCA Member Photos
Getting ready for the 4th of July Parade
Interesting Delivery
32' Oldsmobile Dovetail Receptacle
32 Special Bracket ID
Chevrolet Trim Plate
Pilot Bushing Removal Tool artile
VCCA Member Projects
53rd installment - '28 engine tear down
52nd installment - '28 engine tear down
51st installment - '28 engine tear down
50th installment - '28 engine tear down
49th installment - '28 engine tear down
Topic Options
Rate This Topic
#386306 - 03/24/17 04:25 PM 1969 LeFrance 900
Billu38 Offline
Loc: Florida, USA
friend of mine bought a 1969 LeFrance 900..in-line 6 Continental engine...602 cu inch....having trouble figuring out whether it's a 12V or 24V and whether pos ground or not...any help here? Billu38
Top
#386337 - 03/25/17 09:27 AM Re: 1969 LeFrance 900 [Re: Billu38]
tonyw Offline
Loc: Goulburn Australia
If there are batteries installed, check which way they a connected if positive to positive or 2 battery posts on each lead it is 12v but positive to negative with a short cable between batteries it is 24v.
No batteries possibley makes it a little more difficult, the generator and starter motor OFTEN are stamped 12v or 24v, without this stamping it takes a bit more investigation.
_________________________
Top
#386340 - 03/25/17 12:38 PM Re: 1969 LeFrance 900 [Re: Billu38]
m006840 Offline
Loc: merrimack nh
Check the battery cables to see if they go to a series parallel switch as that would supply 24 volts to the starter while the rest of the system remains 12 volt. Remove a lighting bulb as they are usually marked. If 12 volt the starting system could still be 24 volt as noted previously. The voltage regulator should be marked for pos or neg ground.
Top
#388748 - 05/05/17 11:32 PM Re: 1969 LeFrance 900 [Re: Billu38]
MikeDenbar Offline
Loc: Virginia
Did you figure out the answer to your question? I can get you a contact to get you information if you need. Google the Old Dominion Historical Fire Society. Check out the owners photos. There should be a 900 and you should be able to connect with the owner. If not, let me know and I can hook you up. Mike Denbar
Top
#389565 - 05/22/17 12:27 PM Re: 1969 LeFrance 900 [Re: Billu38]
Billu38 Offline
Loc: Florida, USA
Thanks Mike..I will pass info on...Billu38
Top
Moderator:  ken48
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
0 Chat Members (), 1 Guest and 28 Spiders or Bots online.
Key: Admin, Global Mod, Mod
We speak Chevy!
Time Flys!
Since 12/16/2001
Previous Photos
Newest Chat Registration
Emanuel, DrDoug, ronp, ChevyNC, 5pcoupe
14739 Registered Users
VCCA Info Links
NEWBIES START HERE
CHAT HELP
Send My Password
Kill My Chat Cookies
VCCA Home
G&D Calendar
Judging
Club Regions
Join Info
Forum Stats
14739 Chat Users
77 Forums
48874 Topics
Max Online: 304 @ 06/18/16 10:00 AM
See the USA
In your
Dinah says Hi!!
