#389410 05/19/17 12:54 PM
Pat S Offline OP
My '34 has a leak that disappears when the tank is below half. I suspected the pickup tube as it is about halfway up the front wall. I pulled the tank, filled it with water and sure enough it comes from two spots in the soldering around the pickup tube. What is the preferable way of fixing that?
[Linked Image from i1176.photobucket.com]://s1176.photobucket.com/user/landman2/media/IMG_5688.jpg.html][Linked Image from i1176.photobucket.com][/URL]
Pat S #389448 05/20/17 06:56 AM
I would be getting the soldering iron hot, tipping the tank so the contents is away from the joint and resoldering it. Dont use a flame near the tank, with a flame heated iron do that well away from the tank but a electric iron will be fine. You will need a large body iron or high wattage electric.
You may end up completely removing the pipe, thoroughly cleaning and refitting to get it to seal fully.
tonyw #389474 05/20/17 07:08 PM
Pat S Offline OP
Thanks Tony. I showed it to the guy who had machined the knees to accept bushings and he says he'll look after it. Looks like he's fixed several before. He says he'll pressure test it too.
Pat S #389979 05/30/17 08:08 PM
Pat S Offline OP
Tank is resoldered and back in the car. It has 2-3 gallons of gas and the car has run. Now if it could only stop raining long enough to fill it up.Then we'll know for sure.
I stuck my engine shop in there by mistake. Here's the photo I wanted to post
Pat S #389980 05/30/17 08:13 PM
Very cool looking models there! Thought the scene was real except the floor is too clean lol. Gas tank soldering looks good too.
Pat S #389990 05/31/17 04:19 AM
I like your engine shop, would like to have it at my place. The soldering job looks good too.
