#389249 05/16/17 06:43 AM
Do anyone know the size of the V8 engine block itself? Either 265 CID or 283 CID.
length from front of block to back of block?
width at oil pan surface?
width at intake manifold surface?
width from cylinder head surface to other cylinder head surface?
height from intake manifold surface to oil pan surface?
I wish to create 3D model of the engine.
Wilwood Engineering1955-1957
IF YOU MAKE A VISIT TO ANY AUTO WRECKERS THEY WILL HAVE THEM LAYING AROUND ON THE GROUND, OUT OF THE CAR.
JUST FLASH YOUR TAPE AND WRITE DOWN EVERYTHING YOU NEED IN INFO.
MIKE Agrin
Your qestion was answered on the Chevy Talk forum.
