#388969 05/10/17 10:05 AM
HELP! Would someone familiar with a 1939 GMC COE radiator set-up please respond. I am guessing the Chevy COE would be similar. I have a problem with the radiator fill because I am building from scratch and have never seen what is supposed to have been. Thanks Mike Denbar
MikeDenbar #389041 05/11/17 09:59 AM
Hi Mike,
I don't have the answer to your question, but I ran across this article and thought you'd enjoy it: http://www.oldchevytrucks.com/blog/index.php/2017/05/1948-gmc-coe-deluxe-crew-cab/
MikeDenbar #389161 05/14/17 10:54 AM
Mike,
I don't know if this helps or applies. On the '41-'46 Chevy C.O.E., The radiator has a smooth neck. A short length of straight hose connects it to the filler neck (with cap).
A bracket or clamp secures the metal neck and cap to the firewall.
I'm not looking at this setup at the moment so I am going from memory. I never understood why the extra upward extension was needed.
35Mike #389172 05/14/17 04:43 PM
mike denbar , sent you a PM with friend who has a 39 coe .
Hope he can help you out.
mike lynch......................... Agrin
35Mike #389215 05/15/17 03:13 PM
Mike, Thanks, but mine is set up differently. I guess the radiator that was given to me (did not come with the truck)went to a truck that had the cowl flip up like a hood. Mine does not do that. I figured out how to manage it. Thanks
MikeDenbar #404547 03/08/18 10:49 PM
A local junkyard has a 39 or 40 in it and I think it still has a radiator,
VCCA #45194
