Posts: 22 |
We have about completed our 57 Chevy. It has the original 283 with a 2-brl carb and auto transmission. The engine rebuilder said it would not hurt the engine to run "regular unleaded" gasoline (without any lead substitutes). I have also been told by others that I need to run the gas with lead substitutes. We kept the engine as from the factory (no hardened valve seats, etc.) What is the "normal" recommendation on gasoline? The car has less than 42000 actual miles. However, we bored the engine .030 over, new stock cam, new lifters, reseated the valves, etc. Anybody have any experienced recommendations? Thanks for the help.
Lead substitutes are of no value and not necessary.Unleaded gas will cuase no engine problems.Infact it can eleminate lead and carbon deposits - which can cause valves to burn.
Posts: 3,542 |
Hardened seats are a good idea when you rebuild the motor.
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
Hardened seats put more money in the pockets of the engine rebuilders and parts suppliers. They are only a good idea for vehicles that pull heavy loads, are driven at sustained high speed and other conditions where the valve and head temperatures are elevated above normal. Anyone want to buy a 200 mi./gal. Fish carb? How about a water injector? Super spark module? Nothing against those that have been convinced that they are good and necessary except to say to do your homework and just don't believe everyone. Believe me!???
Posts: 2,142 Likes: 3
Posts: 2,142 Likes: 3 |
I think Chip summed it up. I have over 15,000 on my 348 since the rebuild, I have no problems. Installtion of seats can really stress the heads. Also 30 over on a pre 63/64 283 is nothing! John
John
Posts: 22 |
Wow! Thanks for the information. We will go with what the engine rebuilder advised...nothing but unleaded gas and nothing added. We think we will have the car ready to drive sometime around the end of January of 05. Thanks for the help.
Posts: 11,162 |
How about the need to Run Super unleaded or just go ahead and use regular unleaded for highway touring in a 1968 Impala 327 275 HP with auto , A/C pb & Ps?
I think the compression ratio was 10.1 new?
I drove it about 25 miles the first time out today, It had not been driven for the last 2 years. I found and replaced a bad modulator vacuum unit, it was bent like it had been used to jack the car up with and the vacuum hose was not attached, I also replaced the filter in the 400HT cleaned the 4bbl. (pulled it off and washed it out with B-12 with out taking the float bowl off), checked the timing and points and ran the vacuum and fuel pump pressure meter. We wil leave in the morning on a 400 mile warm up tour and Toy run.
If the timing is set to factory specs premimum fuel will be required.Its listed as a 10.25 C.R....With high humidity and an easy right foot regular or mixture of the two will get you by during cooler times of the year.
Posts: 11,162 |
Book says 4 degrees, that is what it checked out, I got a Pertronix set and coil to put on next week I will listen for the tell-tale pinging, haven't heard any yet, barely warmed up the ATF and coolant today. I don't mind paying for Premium or Super Unleaded if it is needed.
I believe that good oil and fuel is the cheapest thing you can put into an automobile.
Posts: 3,542 |
"Opinions on hardened seats vary..."
Posts: 959 |
Posts: 3,542 |
Valve Seat Installation Procedures
by Larry Carley, Technical Editor
lcarley@babcox.com
Valve seats are an extremely important part of a cylinder head because the seats cool and seal the valves. They also support the valve when it closes, which affects both valvetrain geometry and valve lash. If a seat is damaged, cracked, loose, receded or too badly worn to be recut or reground, it can cause a variety of problems: loss of compression, valve burning, valve failure, valvetrain wear and breakage, even head and valve damage if the seat comes loose.
For that reason, replacing valve seats is often necessary when reconditioning aluminum or cast iron cylinder heads. Another reason to replace a seat is if a valve has broken because the seat is not concentric with the guide. Misalignment between the seat and guide causes the valve stem to flex every time the valve closes. Eventually, this flexing leads to metal fatigue and valve failure. When this happens, the counterbore must be remachined (if the head is salvageable) to realign the seat with the guide.
New seats may also be required if a cylinder head has been straightened or welded, if there’s any evidence of corrosion around the outside diameter of a valve seat, or if the engine is being converted to run on a dry fuel such as propane (LPG) or natural gas.
Integral seats in cast iron heads are no less important even though the seats are part of the head itself. An integral seat may have to be cut out and replaced with a new insert if the seat has receded, is badly worn or damaged.
How Often? Some experts say when late model aluminum heads are reconditioned the valve seats should always be replaced to maintain correct valvetrain geometry. This applies to overhead cam engines as well as pushrod engines. It’s expensive but is usually necessary to restore proper installed valve height and valvetrain geometry.
Rick Emert, product and technical services manager for SB International, says most valve seat failures (more than 50 percent) are due to one of two things: misapplication (wrong valve and seat combination) or valvetrain "mismotion" (incorrect valvetrain geometry or lack of seat/guide concentricity). He also explains that preignition causes a lot of seat failures, too.
"When seats get too hot, microwelding occurs between the valves and seats. The valves are harder than the seats so microscopic particles of metal from the seats stick to the valves," says Emert. "When the engine cools, these particles are then washed into the exhaust. This causes rapid recession of the seats and is most common in dry fuel (LPG or natural gas) engines."
Emert said another reason for replacing seats in some late model heads is because the OEM powder metal seats become too hard to machine. Many late model gasoline engines with aluminum heads from ****, GM, Chrysler and many imports are factory-equipped with sintered powder metal seats. Powder metal seats are used because they are harder and more durable.
Powder metal seats combine various materials to achieve special properties. Many powder metal formulas work-harden as the engine runs. A new powder metal seat that has a hardness of RC 25 when it is first installed will develop a hardness of RC 40 to 50 after several thousand miles. Seats that hard are difficult to refinish by cutting, so one alternative to grinding is replacing the old seats with new powder metal or alloy seats.
Emert says his company recommends alloy seats for most applications because they are easier to machine. "We have eight different alloys in our product line, and each one is engineered for a specific type of application." His company’s two most popular alloys are "Cast XB" (an iron-based alloy), and "N-Series" (a nickel-based alloy). SB International also has powder metal seats for those who want to install the same kind of seats as original equipment, Emert says.
"But we don’t recommend installing powder metal seats in diesel engines because powder metal seats can’t take the heat and compression in this kind of application. They may shatter," says Emert.
Other valve seat manufacturers offer a variety of different alloys for valve seat inserts, as well, including various powder metal formulas. But powder metal has been slow to catch on in the aftermarket. Although engine rebuilders are seeing more late model heads, many still prefer to use alloy inserts.
However, Bill Dolak of Dura-Bond says traditional cast iron seats won’t hold up well in late model engines. He recommends one of two different alloy seats depending on the application, either the "30000 Gold Series" valve seat inserts made of finely dispersed tungsten carbide in a matrix of tempered tool steel and alloy iron particles, or his company’s "70000 Diamond Series" inserts which use a higher temperature mix of tool steel and tungsten carbide. He says the 30000 Gold Series seats are easily machined and offer good wear and heat resistance for naturally aspirated and turbocharged engines. For high performance, heavy-duty and dry fuel applications he recommends the higher temperature 70000 Diamond Series inserts.
Dale McKitterick of Precision Engine Parts clarifies what alloys are appropriate for which applications. His company offers high chrome alloy seats (which are good for unleaded gasoline engines in most passenger car and light truck applications), nickel alloy seats and M2 tool steel alloy seats (for severe duty, high temperature applications), ductile iron seats (popular with many race engine builders) and beryllium/copper seats (used mostly in megabuck high end racing engines). McKitterick says he also has powder metal seats, but only a few customers have asked for them.
Qualcast, Tucker Valve Seats, Martin Wells and others all offer a variety of different alloy seats for various types of engine applications. The important point here is to choose a replacement seat that is right for the application. Higher load, higher temperature applications require harder seats. Follow the recommendations of the valve seat insert suppliers because they know what works best in each type of application.
Cast iron inserts are still used for light duty intake valve applications but should never be used on the exhaust side. The metal is just too soft to withstand the operating temperatures. For exhaust valves, a hard insert made of high chrome stainless steel, high nickel alloy or a heat resistant alloy must be used. Stellite inserts, which are made of a nonmagnetic cobalt alloy and are the hardest inserts available, are recommended for the exhaust valves in heavy-duty, high temperature engines and those that burn dry fuels such as propane or natural gas.
Tom Tucker of Tucker Valve Seat, says 440 stainless steel seats or Silicone XB (an iron seat with 18 percent chrome) are the most popular aftermarket seat materials today. But he also stressed the importance of choosing a seat that’s designed for a specific application.
"We have a tool steel tungsten carbide material for natural gas applications that holds up especially well. We also have an ”˜E’ series material that provides superior hot hardness but is not as hard or abrasive as #3 Stellite."
Roger Klump of Martin Wells says his company has been selling its Well-Tite alloy for more than 30 years and he’s never seen a failure with the product. "It has the same wear characteristics as a 52 RC Stellite-type of product but with a hardness of only RC 35 to 37," explains Klump. "The Well-Tite alloy contains 42 percent nickel, which provides good heat transfer and valve cooling. It also contains 10 to 12 percent chrome for oxidation resistance, and 7 percent moly for toughness."
Preliminary Steps Seats should not be replaced until the head has been thoroughly cleaned and inspected. This includes checking for cracks (especially around and near the valve seats) and checking the deck surface and cam bore for straightness. Any welding and/or straightening that may be needed must be done before remachining the valve seats or installing new inserts.
Also, the valve guides should be replaced or reconditioned before the seats are machined. Concentricity between the seat and guide is absolutely essential for a proper alignment, good compression and long term valve durability.
The cylinder head must be dimensionally and geometrically within specifications before seat counterbores are machined. That includes cylinder head thickness, valve guide clearances, concentricity and perpendicularity. There should be no warping, twisting or any type of misalignment anywhere in the head.
Seat Removal The first step in seat replacement is removing the old seats. A variety of methods can be used to remove valve seat inserts from aluminum heads. Putting the head in a cleaning oven is sometimes used to loosen the seats enough to where they may fall out. Knowing the secret password necessary to keep good seats in place while allowing the damaged heads to release is critical (of course, there is no password). Using an oven in this way is a lengthy process that offers no real "predictability" regarding seat loosening.
Another method that does not involve heat is to use a cutter slightly smaller than the outside diameter of the existing valve seat insert to cut away most of the old insert (this works on softer alloy seats but not very well on powder metal seats). Stop cutting when the old seat begins to rotate in the head. What remains of the old seat can now be easily removed.
Another method of cutting out a seat is to use a die grinder to slit and weaken the seat. Just be careful not to cut all the way through the seat and into the counterbore.
Prying out valve seats also works if there is enough of a lip under the inside edge of the seat, but this technique also risks damaging the counterbore if not done carefully.
To remove hard seats, arc weld a bead all the way around on the seat. As the bead cools, it will shrink and loosen the seat. For more information on this procedure, see the March issue of Engine Builder, page 28, "The Whys and Hows of Welding Aluminum."
Another trick is to place a valve that’s somewhat smaller than the seat in the head and weld the valve to the seat. The valve stem can then be used like a driver to push out the seat.
Once the inserts are out, check for cracks or erosion damage under the seats in the counterbores … a common problem on many aluminum heads. If cracked or eroded, the metal can be rebuilt by TIG (tungsten inert gas) welding, and remachining the head to a new seat.
Cutting Counterbores Many experts recommend recutting the counterbores to accept new oversized seats. Some engine builders will install new standard-sized inserts in the existing counterbores. It works on some large cast iron cylinder heads with thick walls, but it’s risky on most automotive applications. The recommended approach is to remachine the counterbores to accept oversized inserts. This allows you to control the interference fit between the seat and head so the seats don’t come loose.
Recutting the counterbore also allows you to control runout in the counterbore and concentricity with the valve guide. The counterbores must be smooth, round, have flat bottoms and be centered to their valve guides for proper alignment and good heat transfer between the seat and head. The final dimensions of the counterbores must be within .0005˝ for the proper fit.
If a counterbore is too rough, distorted or out of round, it won’t make good metal-to-metal contact with the seat. It can also distort the seat. This will reduce heat flow from the seat to the head and make the valve run hot. That you don’t want because it leads to valve burning and warranty problems down the road.
If you’re replacing an integral seat in a cast iron head (and the cylinder head has enough thickness to accept a new seat), the counterbore should be cut to a diameter approximately .100˝ larger than the valve head diameter. The inside diameter of the replacement seat will typically be about .100˝ smaller than the valve head diameter and require a depth of about .188˝ to .250˝ depending on the application.
Accurate cuts also require proper fixturing. Keep your tooling setup as "short and tight" as possible to assure maximum rigidity. The less deflection in the tooling, the more accurate the dimensions of the cut and the greater the concentricity of the counterbore.
Be careful not to distort or put a twist into the head when clamping it to a fixed rail holding fixture.
You’ll get the most accurate cut with correct size pilots (which must be straight), and using the correct spindle speeds and feeds. Machining recommendations vary depending on the type of equipment and tooling used, but Dura-Bond recommends using cutting oil and a spindle speed of 400 to 600 rpm when cutting valve seat counterbores in aluminum heads. When cutting cast iron heads, Dura-Bond recommends using no lubrication and a slower cutting speed of 100 to 250 rpm.
Something else to keep in mind when cutting counterbores is that the seats for many late model heads don’t go by fractional sizes anymore. Seat sizes can vary considerably so using a fixed size cutter is not the best choice. An adjustable cutter will provide the flexibility you need to properly size the counterbores.
Interference? The recommended amount of interference between the valve seat insert and head may vary depending on the size of the insert, the type of insert (alloy or powder metal) and type of head (cast iron or aluminum). The best advice is to use the amount of interference recommended by the OEM engine manufacturer.
Too much interference runs the risk of cracking the head while too little interference increases the risk of the seat coming loose or falling out. One of the leading causes of seats coming loose, however, is not the amount of interference between the seat and head but elevated operating temperatures. Anything that causes the exhaust valve to run hot may also cause the seat to loosen.
Philip Carrasco at Tucker says seats may require anywhere from .002˝ to .010˝ of interference depending on the application and the roughness of the surface in the counterbore. For aluminum heads, an interference fit of .005˝ to .007 ˝ is commonly used. For cast iron heads, .003˝ to .005˝ is about right.
Martin Wells’ Roger Klump says he recommends an interference fit of .005˝ to .006˝ for everything, aluminum and cast iron.
Rick Emert of SB International says he tells his customers to use .005˝ press fit when installing seats in cast iron heads, and .007˝ minimum in aluminum heads regardless of what type of valve seat inserts they are installing. "We do not recommend using any type of locking fluid, staking or peening when installing seats. You should be able to put a concentric seat into a concentric hole with the right amount of interference and have it stay there," says Emert.
Carrasco, on the other hand, says a lot of engine builders have had success using a locking fluid. "They tell me it helps fill any voids between the seat and head for improved heat transfer and valve cooling. You don’t see many production engine rebuilders doing this but you do see smaller shops doing it," said Carrasco.
Seat Installation Installing the new seats once the counterbores have been cut is a fairly simple procedure. A piloted driver is used to push the seat into position. Many aftermarket seats have a bevel or radius on the outside lower edge to make installation easier. Make sure this side faces down when installing the seat.
Some engine builders preheat the head or chill the inserts in a freezer or with nitrogen prior to installing them to make the job easier. Others say this should not be necessary if you use the normal amount of interference fit. Even so, it’s another trick that may come in handy on a problem head or application that requires something out of the ordinary.
Seat Finishing After the seats have been installed, they can be finished as required. The guides must be reconditioned or replaced before doing this, however, because all seat work is done by centering off the guides.
Seats should be as concentric as possible for a tight compression seal and proper valve cooling. The rounder the seat, the better. Seat runout should not exceed .001˝ per inch of seat diameter. Some shops aim for .0005˝ or less of runout. The best way to check concentricity is with a runout gauge. Pulling vacuum on the valve port with the valve in place is another method for checking the mating of the seat and valve. But the ability to hold vacuum is no guarantee of concentricity. Both methods should be used to check the quality of your work.
Seat width is also important for good heat transfer, proper sealing and long valve life. If the seat is too narrow, wear resistance and heat transfer can suffer. And if the seat is too wide, there may not be enough pressure to provide a tight seal. A wide seat also tends to trap deposits that can hold the valve off its seat. This too, can reduce heat transfer as well as compression. As a rule of thumb, the ideal seat width for intake valves is usually around 1/16˝. For exhaust valves, it’s 3/32˝ … or whatever the manufacturer specifies.
The point at which the valve and seat mate is also important. If the area of contact is too high on the valve face (too close to the margin), the valve may be sunken into the head. This increases installed height, upsets valvetrain geometry and restricts free breathing. If the area of contact is too low on the face (too far from the margin), the valve will ride too high on the seat. As the engine warms up and the valve expands, the contact point moves down the valve face away from the margin. The valve may lose partial contact with the seat causing it to lose compression and run hot.
Ideally, the valve should contact the seat about one third of the way down the valve face (about 1/32˝ from the margin) so there is about 1/64˝ of overhang between the margin and top of the seat. EB
BACK TO BASICS … Valve Seats
The most critical sealing surface in the valve train assembly is between the face of the valve and its seat in the cylinder head when the valve is closed. Leakage between these surfaces reduces the engine’s compression and power and can lead to valve burning. To ensure proper seating of the valve, the valve seat must be:
Correct width Correct location on the valve face Concentric with the guide (less than .002˝ runout). The ideal seat width for automotive engines is 1/16˝ for intake valves and 3/32˝ for exhaust valves. Maintaining this width is important to ensure proper sealing and heat transfer. However, when an existing seat is refinished to make it smooth and concentric, it also becomes wider. Wide seats cause the following problems:
Seating pressure drops as seat width increases. Less force is available to crush carbon particles that stick to the seats. Valves run cooler, allowing deposits to build up on them. The seat should contact the valve face 1/32˝ from the margin of the valve. When the engine reaches operating temperature, the valve expands slightly more than the seat. This moves the contact area down the valve face. Seats that might contact the valve face too low might lose partial contact at normal operating temperatures.
Like valve guides, there are two types of valve seats … integral and insert. Integral seats are part of the casting. Insert seats are pressed into the head and are always used in aluminum cylinder heads. Most pre-1978 integral seats are soft cast iron. After 1978, most manufacturers began to produce cylinder heads with induction hardened cast-iron seats able to withstand the higher heat of exhaust applications. Insert seats are added to the cylinder head after casting, or as replacements for worn integral seats.
from the book:
"Complete Automotive Engine Rebuilding and Parts Machining"
Posts: 3,542 |
OR:
Lead - Part 2 The story of leaded petrol involves Thomas Midgley, Jr. He was a chemist, back in the days when "Better Living through Chemistry" had nothing to do with drugs. Originally, his ideas were thought to be brilliant. Only later did they turn out to be disasters.
In 1921, he found that tetraethyl lead was a superb chemical to add to petrol to stop "knocking" in car engines. Today, children in cities all over the world are getting lower IQs, because their brains have been poisoned by lead.
He then invented chlorofluorocarbons - and we all know how these wonderful chemicals have punched a "hole" in the ozone layer. In fact, the "hole" in 1992 is the widest and deepest ever recorded.
In 1940, Thomas Midgley, Jr. was paralysed by polio. He built an assembly of pulleys and ropes so he could move himself between his bed and his wheelchair. In 1944, he became entangled in the ropes, and strangled to death in his own invention.
But in the 1920s, tetraethyl lead was a wonderful invention. When your spark plug fires, it ignites a flame front which travels through the combustion chamber, burning the petrol:air mixture. Tetraethyl lead made the flame front travel more slowly, and also less turbulently. Lead virtually eliminated knock. Overnight, compression ratios jumped from 4:1 to 7:1, and the modern high-output engine was born.
But leaded petrol had even more benefits. As it burns, tetraethyl lead turns into a tan-coloured layer of lead oxide, which covers the valves and the combustion chamber. The valves hit hard against the valve seats several thousand times each minute. The lead oxide acts as a cushioning agent, and protects the valve and the valve seats. The lead oxide is also a lubricating agent. This reduces wear in the valve guides, as the valves slide inside them.
If you start running your old leaded engine on unleaded petrol, the lead oxide quickly wears away. Damage begins, but only if your engine was made with "soft" metallurgy, and only in high-temperature areas - exhaust valves, exhaust valve guides and exhaust valve seats.
At high temperatures, iron oxides form on a "soft" cast-iron valve seat. These oxides flake off and actually embed themselves (as hard nodules) in the "soft" face of the exhaust valve. These hard nodules work like tiny grinding wheels as the valve rotates. They grind away at the valve seat, making it recede into the head. At first, the valve-adjusting mechanism takes up the slack. Eventually, the adjustment is all used up, and the valve no longer closes completely. Then the edges of the valve quickly burn away - so you get what the mechanics call a "burnt valve".
It's quite easy to modify your leaded cylinder head to run on unleaded petrol and never get damaged (if it has "soft" metallurgy). There are just three changes.
The first step begins with the valve guides. You can install silicon-aluminium-bronze valve guides, but usually only in Double OverHead Cam (DOHC) engines. Silicon-aluminium-bronze is fairly soft, and wears fairly rapidly. This is not important in DOHC engines, where the valve just goes up and down, and doesn't rub on the side of the valve guide. In an engine with tappets, the end of the tappet moves in an arc, and so the valve rubs a little on the wall of the valve guide. In this case, use steel valve guides.
The next step is to install valves that are faced or tipped with hard Stellite. The Lancer engine finally died after 240,000 km, so my mechanic installed Stellite-tipped valves, which had also been nitrite-hardened. Valves with "hard" metallurgy cost about $30-$40. You need to replace only the exhaust valves - you can reuse/recondition the inlet valves. The last step is installing the "hard" valve seats. There are several companies (Federal-Mogul, ACL, etc) that supply after-market valve seats with superior metallurgy. You can ask for Stellite, or hard high-chromium or 60%-alloy valve seat inserts.
Valve seat inserts are usually supplied slightly oversize, to give the correct "interference fit". The installation is critical. The head is heated, while the inserts are cooled in dry ice. It's important to use a heat-transfer compound, to fill in the microscopic roughness in the walls between the head and the valve seat insert. In fact, silicone or oil assembly lubricants can have the opposite effect, and actually behave like a heat barrier.
It was easy to convert the Pug 504. Peugeot made a later engine, which was lead-free. We looked up the catalogue, and retro-fitted the later valves, valve guides and valve seats.
In Oz, only 36% of petrol sold is unleaded. But many people are running their old cars (with the "hard" metallurgy) on leaded petrol, even though they could change to unleaded. If these people did change, unleaded petrol sales would jump to about 60% of total petrol sold. Other older cars can run perfectly well on only one leaded tankful for every four unleaded tankfuls.
If you want the final word on whether you car will run on unleaded petrol, ring the manufacturer, or the NRMA. It's been very painful for me to think I might have damaged my kids. It's so easy to use unleaded fuel. © Karl S. Kruszelnicki
Don't tell my '34 and '39 about all that cr*p---they have run for years on unleaded-no seats-old GM soft steel valves and all. driven at their limit on interstats also....That brown coating on the valve seats is what caused the valves to burn-it prevented the valves from seating (sealing) well in the head. Back in the '30's ,40's and '50's it was common to grind valves between 25,000 and 50,000 miles -with leaded gas.Modern cars often run over 200,000 miles with no valve problesm and I would bet the older cars would have gone at least double of what they did if unleaded was used. The unleaded gas is a blessing for both old and new engines
Posts: 11,162 |
Sic'em Gene! Don't let that Cr*p get a foothold here in "Chevy- Land" I have seen Waukasha overhead valve 145's run for 24-7 for 14 days on natural gas pulling pumping units and only adding oil and shutting them down every two weeks to service the pumping units, then starting them back up for another 14 days.
I'll still stand by Hardened seats put more money in the pockets of the engine rebuilders and parts suppliers. They are only a good idea for vehicles that pull heavy loads, are driven at sustained high speed and other conditions where the valve and head temperatures are elevated above normal. Now for the people who always look in the back seat before getting into their car, have two alarm systems at home, take two fist fulls of herb pills per day, and believe that the government only exists to make their lives more difficult; I would say to put hardened seats in their engine and on their sofa. Just kidding about the engine. Ha, Ha.
Posts: 11,162 |
Heck, JYD I thought the electric chair had been outlawed by the EPA! (Too much unwise use of electric energy).... Down here in Texas, we use lethal injections, after first swabbing the arm with alcohol, to prevent infection, ain't that a H@@T! I bet that would harden your seat!
Posts: 2,157 |
macky, electric chairs emit too much ozone...increases the size of the hole over the antarctic...that's why there's such a delay in frying those guys epi
Posts: 3,542 |
"Opinions vary..."
from the book:
