Posts: 269 |
When I try to pull out hard in first or second the car bucks so bad I have to let off the gas and sometimes upshift. It typically happens before the engine is totally up to temperature. I am thinking it may be to lean. It seem fine after it gets hot.
31 Chevy Roadster 64 Corvette 76 Corvette 77 Grand Prix
Posts: 295 |
It sounds like our choke may need adjustment. Try setting it a little to the rich side. When it's cold, remove the air cleaner and open the throttle. The choke blade should snap shut. If it's not doing that, it's set too lean.
Verne
Posts: 269 |
Thank you Verne, I wanted some confirmation before I started adjusting.
0 members (),
91
guests, and
22
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
