#387626 04/14/17 07:05 PM
Hawkeye Offline OP
For those of you who have installed this type of material to the floor, is it okay to install anytime or just before you install the carpeting? I still have work to do inside the cabin and do not want to ruin this insulation material. Thanks
I go with anytime. It is nice to know that below the deadener you have a solid, repaired, and painted floor. I am not going to add anymore deadener to my floor until I hear how my insulated carpet works out.
Good luck, Mike
If you install the insulation and need to work inside the body just lay some cardboard or a movers mat over it. Harbor Frt. has a movers pad for around $6.00-cheap protection.
Wood floors and sound deadening adhesive wasn't fun to remove...
