Posts: 1,005 Likes: 5
Posts: 1,005 Likes: 5 |
For those of you who have installed this type of material to the floor, is it okay to install anytime or just before you install the carpeting? I still have work to do inside the cabin and do not want to ruin this insulation material. Thanks
Posts: 2,306 |
I go with anytime. It is nice to know that below the deadener you have a solid, repaired, and painted floor. I am not going to add anymore deadener to my floor until I hear how my insulated carpet works out.
Good luck, Mike
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
If you install the insulation and need to work inside the body just lay some cardboard or a movers mat over it. Harbor Frt. has a movers pad for around $6.00-cheap protection.
Posts: 1,381 |
Wood floors and sound deadening adhesive wasn't fun to remove...
