Vintage Chevrolet Club Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
VISITORS: You are welcome to read our forums. If you want to participate FREE then you need to register. Join the VCCA and get access to the member-only features of the forum, including the ability to attach/upload photos. You'll also receive our monthly magazine "Generator & Distributor". Yearly membership as low as $25!
VCCA MEMBERS: Already a member? Great! Info to access the members-only area.
Topic Options
Rate This Topic
#387246 - 04/08/17 04:37 AM Smoking wire under the dash
Jonda1 Offline
Loc: Apple Valley, California
I'm driving the 33 Chevy Master and get a couple of puffs of smoke from under the dash. I looked and see the metal tubing that surrounds the ignition wire that goes through the firewall has maybe shorted the ignition wire. Sometime in the last 84 years someone pulled the switch and tubing apart and it's missing pieces. I think I will try to remove the wire from the tube and run new plastic coated wire through the tube to the coil.
Top
Vintage Auto Garage - 6 Volt
#387248 - 04/08/17 10:28 AM Re: Smoking wire under the dash [Re: Jonda1]
tonyw Offline
Loc: Goulburn Australia
I have not seen the electrolok setup so I could well be wrong but to me that looks like the ignition switch has been changed out to a later style which may well be a major cause of your problem.
_________________________
Top
#387251 - 04/08/17 11:13 AM Re: Smoking wire under the dash [Re: tonyw]
Mike Buller Offline
1500
Loc: MI, USA, Midland
A little more info on your ELectrolux/Electrolock problem. I think it is reasonable to assume that the wiring on this component should be replaced, just like the wiring harness after a set number of years. In many cases this could be as little as 40 years depending on whether the vehicle has been exposed to NORMAL usage, where it was stored, and whether it had ever been serviced.
By the looks of your dash wiring you can see that it has been updated through the years. Probably, the remaining original wire, should be replaced.
Another Electrolock Question 1938
1946 1/2 Ton Ignition
Good luck, Mike
P.S. Here is a picture of the wire harness under my headliner before I replaced it a few weeks ago. 41 Headliner
Mike 41/77 Chevys
Top
#387252 - 04/08/17 12:30 PM Re: Smoking wire under the dash [Re: Mike Buller]
Mike Buller Offline
1500
Please disregard the term Electrolux, which is a brand of vacuum cleaners, in my above post.
Thanks, Mike
Mike 41/77 Chevys
Top
#388542 - 05/01/17 12:24 AM Re: Smoking wire under the dash [Re: Mike Buller]
41specialdeluxe Offline
Loc: NC usa
Mike,
Not so fast there, good buddy. dance2
You made a great mistake right there and we are going to think of you as the electrolux man from now on and throughout eternity. dance
Yep, every time we see the name Mike Buller, from now on, we will instantly create the mental picture of you wearing your wife's frilly aporn and a-vacuuming the living room. Will too! willy
Sorry about that, Agrin
Top
Moderator:  AntiqueMechanic, Coupefan
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
1 Chat Members (Peter_Gariepy), 1 Guest and 28 Spiders or Bots online.
Key: Admin, Global Mod, Mod
Today's Birthdays
32confederate
Helpful Links
Forum Registration
New User Forum
Members Only Forum
Reset Your Password
Kill Your Cookies
VCCA Home
Join the VCCA
Member Photos
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
1936 Roadster - S. Africa
Chevy on the Levee
'37 Seat
Forum Stats
15086 Chat Users
79 Forums
50178 Topics
Max Online: 304 @ 06/18/16 10:00 AM
