#386519 03/28/17 12:57 AM
Jonda1 Offline OP
Hi, my car is a 1933 Master 5 Window Coupe. The drivers door window sometimes will not roll all of the way down. And then sometimes when it does roll down all of the way it won't roll back up. Is there any trick to pulling off the door panel to check it out?
Thanks,
Dennis Jones
You have to remove the interior door and window handles and that will take a special tool to remove the horseshoe clips that hold the handles in place. Then, you will have to remove the interior door panel to get to the window regulator mechanism. The interior door panel should be blind nailed in place, so you will need to carefully pry off the door panel.
Do you have a Fisher Body Manual?
