#386296 03/24/17 10:22 AM
6wheel Offline OP
My 55 hardtop has wind noise at the upper part of the door windows. They have a rubber seal that runs the length of the inside of the flipper. Is there supposed to be an additional seal or seals at the front of the flipper?
Thanks.
Sid
Wilwood Engineering1955-1957
6wheel #386301 03/24/17 11:25 AM
I could be wrong but I do not recall any rubber strips inside of the flipper. Does it look like some thing some one stuck in there? What I do remember is some models had fuzzy strips.
Wind noise was quite common on hardtop models, even when new, so it may be a up-hill fight.
Chev Nut #386303 03/24/17 11:43 AM
6wheel Offline OP
Thanks Gene, There is a small extra piece of rubber at the front on each side. The piece on the driver's side is more worn than the one on the passenger side. Someone looking at it recently thought there was supposed to be an extra seal there. In looking at Eckler's catalogue, I don't see such a seal.
6wheel #386316 03/24/17 04:56 PM
I looked in the parts book and didn't see one either.
6wheel #386322 03/24/17 08:45 PM
Don't remember an extra seal but some have a rubber or plastic coating on the tab that closes the flipper. Maybe a little thicker piece would put more pressure on the glass and give a better seal.
Chipper #386324 03/24/17 09:07 PM
Yes, that is a little nylon piece and is still available.
Chev Nut #386360 03/25/17 03:16 PM
6wheel Offline OP
A part that appears to be nylon in Ekler's catalogue is called a "flipper tab". Possibly that's the part you are talking about. I think I need to replace all the rubber parts as well. Is there a diagram of this flipper assembly somewhere? I don't see it in the shop or assembly manuals.
Thanks,
Sid
6wheel #386362 03/25/17 03:44 PM
Danchuck sells the 1955 flippers for $199 a pair, Also has the front rubber piece.
The flippers probably would be in the Fisher Body manual or bulletins.
Chev Nut #386425 03/26/17 07:05 PM
6wheel Offline OP
Thanks guys. I'll check it out.
Sid
