Posts: 1,623 |
Here's a dummy question. The commonly seen little round orange decal, which goes over one terminal on the Generator - ("Generator Warning Tag" I think it is called). It was used all through the 50s and early 60s. Is the reproduction a true "decal" - do you peel and stick it, water it, what? Or does it just lay there and not really a "decal" at all? It doesn't seem to want to peel, I doubt it is water based.
Chevy Guru
Posts: 29,847 |
Posts: 30,699 Likes: 141
Posts: 30,699 Likes: 141 |
They are not a decal. Just placed under the terminal and lay against the generator. What year were they first used?
Posts: 1,623 |
Thanks, Gene. It seems like I remember seeing them back in 6 volt applications, back into the late 40's - 1950 era. Not sure.
Chevy Guru
thats what my thinking was also.
Posts: 1,623 |
I'm finally back to work on my '56 wagon after a year and a half idle. It still had the remnants of that generator tag in place - first time I ever saw one that was still there from the factory - so I thought it deserved a new one after rebuild. The old original had glued itself down to the generator body which is why I asked. Not much left of it but blank white paper.
Chevy Guru
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
the 53 corvettes had the thick paper label for sure. can say if pre 53 chevys used them tho. mike
Posts: 29,847 |
Posts: 1,623 |
Well, Dog, in all fairness, Gene's post is only 6 minutes after yours. He had probably already started to answer when yours popped up, and he didn't see it before posting his own. Just like I said "thanks Gene" and didn't include you - because I saw Gene's answer before I realized you had the same answer right above it! So - thanks, Skipper, a little late.
Chevy Guru
2 members (Rustoholic, Stovblt),
77
guests, and
21
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,071
Posts429,059
Members18,308
