#386032 03/20/17 10:13 PM
Here's a dummy question. The commonly seen little round orange decal, which goes over one terminal on the Generator - ("Generator Warning Tag" I think it is called). It was used all through the 50s and early 60s. Is the reproduction a true "decal" - do you peel and stick it, water it, what? Or does it just lay there and not really a "decal" at all? It doesn't seem to want to peel, I doubt it is water based.
[Linked Image from i1122.photobucket.com]
Chevy Guru
The tags in question are not decals. The tags that I have, like the one depicted in your photo, are made from card stock and they are attached directly to the base of the generator terminal.
They are not a decal. Just placed under the terminal and lay against the generator. What year were they first used?
Thanks, Gene. It seems like I remember seeing them back in 6 volt applications, back into the late 40's - 1950 era. Not sure.
Chevy Guru
thats what my thinking was also.
I'm finally back to work on my '56 wagon after a year and a half idle. It still had the remnants of that generator tag in place - first time I ever saw one that was still there from the factory - so I thought it deserved a new one after rebuild. The old original had glued itself down to the generator body which is why I asked. Not much left of it but blank white paper.
Chevy Guru
the 53 corvettes had the thick paper label for sure. can say if pre 53 chevys used them tho. mike
I think that I mentioned that above. bigl
Well, Dog, in all fairness, Gene's post is only 6 minutes after yours. He had probably already started to answer when yours popped up, and he didn't see it before posting his own. Just like I said "thanks Gene" and didn't include you - because I saw Gene's answer before I realized you had the same answer right above it! So - thanks, Skipper, a little late.
Chevy Guru
