The only reason people get lost in thought
... is because it's unfamiliar territory.
Today's Birthdays
32confederate, EdLo, ewv715, galen33, Paul Boyd
Featured Chat Guy (or Gal)
VCCA Member Photos
Getting ready for the 4th of July Parade
Interesting Delivery
32' Oldsmobile Dovetail Receptacle
32 Special Bracket ID
Chevrolet Trim Plate
Pilot Bushing Removal Tool artile
VCCA Member Projects
53rd installment - '28 engine tear down
52nd installment - '28 engine tear down
51st installment - '28 engine tear down
50th installment - '28 engine tear down
49th installment - '28 engine tear down
Topic Options
Rate This Topic
#385922 - 03/19/17 04:40 AM I have an extra wire left over
Jonda1 Offline
Loc: Apple Valley, California
I have a 1933 Master 5 Window Coupe. My car wasn't charging so I removed the generator. I pulled it apart and cleaned it as good as I could with some scotchbrite and denatured alcohol. It was in real bad shape. Lots of rust on everything. The brushes looked good so I will keep the new ones I ordered from the Filling Station for a later time. I replaced the cutout relay with the one from the Filling Station with a diode in it. The generator now charges. But while reinstalling it I discovered a wire that seems to go nowhere. It has an eyelet on it, so it should be connected to something. Anyone with ideas on where it connects please let me know. I did check it with a volt meter. When I turn the key to the on position there is still no current in this wire. Also, what should I be oiling this generator with? I sprayed a little silicon spray into the oiling cups. What should I be putting in the generator for lubrication?
Edited by noloco6655 (03/19/17 04:45 AM)
Top
Vintage Auto Garage - 6 Volt
#385925 - 03/19/17 05:59 AM Re: I have an extra wire left over [Re: Jonda1]
Junkyard Dog Offline
Loc: Eagle Point, Oregon
You should use a few drops of a light weight oil in the oil cups.....not silicon spray.
_________________________
Top
#385927 - 03/19/17 07:20 AM Re: I have an extra wire left over [Re: Junkyard Dog]
Jonda1 Offline
Thanks Junk Yard Dog. I will put some oil in it tomorrow. I have been reading the 6V Electrical section and some people are talking about a felt strip in the generator that is used to wik oil to the armature. When I had my generator apart it did not have any felt strip inside it. I am assuming it would be inside that end cap with the three small screws holding it on the end of the generator. I'm thinking I need to find some felt to put in it.
Top
#385942 - 03/19/17 02:57 PM Re: I have an extra wire left over [Re: Jonda1]
That is correct.....there is a felt wick in the end frame of the generator. It is oiled by the oil cup that is on the end frame of the generator. The felt wick should be okay.
Top
#385949 - 03/19/17 07:22 PM Re: I have an extra wire left over [Re: Jonda1]
blue38 Offline
pumpjockey
Loc: phoenix......az
sewing machine oil...o.k ..make in 3in1
Top
#385950 - 03/19/17 07:37 PM Re: I have an extra wire left over [Re: Jonda1]
m006840 Offline
Loc: merrimack nh
The rebuilder of my generator installed sealed bearings. With sealed bearings oil is not necessary.
Top
#385964 - 03/20/17 12:04 AM Re: I have an extra wire left over [Re: m006840]
41specialdeluxe Offline
Loc: NC usa
Seems to me that the engine oil should be good enough for lubricating the generator.
Top
#385967 - 03/20/17 01:15 AM Re: I have an extra wire left over [Re: 41specialdeluxe]
Chev Nut Offline
Loc: West Allis,Wi.
3 in 1 oil is too "thin". Chevrolet said motor oil.
Was there a new wiring harness installed? The little tag near the end of the wire looks like there possibly was. The extra wire may have been for a two wire generator and for ging to the field terminal that you do not have.
Edited by Chev Nut (03/20/17 01:22 AM)
Chevgene
Top
#385971 - 03/20/17 01:47 AM Re: I have an extra wire left over [Re: m006840]
The rear end frame on the 943J generator has a bushing, not a bearing, so oil at that point is definitely necessary.
Top
#386460 - 03/27/17 04:17 PM Re: I have an extra wire left over [Re: Junkyard Dog]
Rusty 37 Master Offline
Loc: Iowa
Just saw this post. Sorry for the delayed input.
I agree with the discussion about the engine oil and felt wick for the rear bushing. Unless your rebuilder completely changed the rear frame of the generator that is not a bearing.
Is the extra wire for the horn? I am not familiar with the details of the wiring or the under hood configuration for the 1933 coupe so that might not be appropriate.
Top
#386465 - 03/27/17 05:25 PM Re: I have an extra wire left over [Re: Junkyard Dog]
m006840 Offline
Loc: merrimack nh
I am not sure what is in the rear end frame. If there is not a bearing then perhaps the builder installed an oilite bushing. He rebuilt both my starter and generator and advised their was only one place that needed oil and it was the bushing in the drive end housing of the starter. I suppose if there is an oil cup in the end frame of the generator a drop of oil won't hurt as it was 16 years ago that they were rebuilt. I can't ask the rebuilder as his memory has failed and perhaps mine is headed the same way.
Top
#386468 - 03/27/17 05:34 PM Re: I have an extra wire left over [Re: m006840]
Chev Nut Offline
Loc: West Allis,Wi.
The starter only get used for short bursts ....the generator is spinning at high RPM sometimes for hours.
Back in the '60's before altenators we were having problem with the rear bushings burning out. Then Delco came out with a change-over kit with a new rear end frame with a ball bearings.
The front bearing in an altenator is the same bearing used in the front of a generator going back into the '20's....but is a sealed bearing.
Mid year in 1948 Chevrolet eleminated the oiler on the starter and went to the oilite bearing.
Edited by Chev Nut (03/27/17 05:35 PM)
Chevgene
Top
#386476 - 03/27/17 06:47 PM Re: I have an extra wire left over [Re: Chev Nut]
m006840 Offline
Loc: merrimack nh
That's very interesting Gene and I will have to check to see what I have. Sometimes the numbers on the tags are misleading. I purchased a starter at a flea market because it had A 714L tag on it. However my local rebuilder says it will not fit my 32 Chevy as the armature and drive end housing are for an Oliver tractor.
Top
#386477 - 03/27/17 06:52 PM Re: I have an extra wire left over [Re: m006840]
Chev Nut Offline
Loc: West Allis,Wi.
Could always find an Oliver Tractor.
The drive end housing could be exchanged. Then would measure the length of the armature to be sure.
Last year I had a 1937 starter and a friend needed a starter for a 1934. Unbolted the '37 housing and installed the '34 housing was all that was needed to fit.
Chevgene
Top
Moderator:  AntiqueMechanic, Coupefan
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
0 Chat Members (), 1 Guest and 36 Spiders or Bots online.
Key: Admin, Global Mod, Mod
We speak Chevy!
Time Flys!
Since 12/16/2001
Previous Photos
Newest Chat Registration
Shermy, CommanderSashi, Emanuel, DrDoug, ronp
14741 Registered Users
VCCA Info Links
NEWBIES START HERE
CHAT HELP
Send My Password
Kill My Chat Cookies
VCCA Home
G&D Calendar
Judging
Club Regions
Join Info
Forum Stats
14741 Chat Users
77 Forums
48874 Topics
Max Online: 304 @ 06/18/16 10:00 AM
See the USA
In your
Dinah says Hi!!
