Don't be stupid
... it might make you famous.
Today's Birthdays
32confederate, EdLo, ewv715, galen33, Paul Boyd
Featured Chat Guy (or Gal)
VCCA Member Photos
Getting ready for the 4th of July Parade
Interesting Delivery
32' Oldsmobile Dovetail Receptacle
32 Special Bracket ID
Chevrolet Trim Plate
Pilot Bushing Removal Tool artile
VCCA Member Projects
53rd installment - '28 engine tear down
52nd installment - '28 engine tear down
51st installment - '28 engine tear down
50th installment - '28 engine tear down
49th installment - '28 engine tear down
Topic Options
Rate This Topic
#385165 - 03/06/17 03:14 PM Distributor oiler
m006840 Offline
Loc: merrimack nh
ON a 1954 distributor number 1112396 is an oiler wick used? My parts book list a spring and grease cup but I did not see a felt wick listed. I removed the cup and spring and if there was a wick there it had completely deteriorated.
_________________________
Top
Vintage Auto Garage - 6 Volt
#385166 - 03/06/17 03:43 PM Re: Distributor oiler [Re: m006840]
Chev Nut Offline
Loc: West Allis,Wi.
Evidently the last year a wick was used for a 235 was 1952. A different wick was used for 216 until 1953 and many listed for 8 Cyl. models that has an actual oiler and no grease cup.
Info. is from the 1959 parts book.
Chevgene
Top
#385178 - 03/06/17 06:25 PM Re: Distributor oiler [Re: Chev Nut]
m006840 Offline
Loc: merrimack nh
Thanks Gene. My 1955 book list about the same info. Any idea what the purpose of the spring is? I don't see anything that retains it or keeps it from contacting the distributor shaft.
Top
#385181 - 03/06/17 06:50 PM Re: Distributor oiler [Re: Chev Nut]
Chev Nut Offline
Loc: West Allis,Wi.
The spring and disc pressed the shaft againt the housing to prevent the shaft forom wobbling and changing the timing if it get worn.....A new "feature" for 1934.
Chevgene
Top
#385182 - 03/06/17 07:03 PM Re: Distributor oiler [Re: Chev Nut]
m006840 Offline
Loc: merrimack nh
Well I see no disc.Is it supposed to be attached to the spring?
Top
#385183 - 03/06/17 07:34 PM Re: Distributor oiler [Re: m006840]
Chev Nut Offline
Loc: West Allis,Wi.
It was a small hard fiber disc and prevented the metal spring from contacting the metal distribtor shaft. Probably ground up back in about 1963. Today a nylon disc would work better I would think.
I sent you a picture
Edited by Chev Nut (03/06/17 07:38 PM)
Chevgene
Top
#385185 - 03/06/17 07:47 PM Re: Distributor oiler [Re: m006840]
Junkyard Dog Offline
Loc: Eagle Point, Oregon
There was a small fiber disc at the end of the spring that rubbed against the distributor shaft. The disc usually wore down to nothing over a period of time and then the end of the spring wore on the distributor shaft making a groove in the shaft. You are better off removing the spring and just leave the grease cup. The grease from the cup will still lubricate the distributor shaft nicely. The disc and spring really are not needed. The earlier distributors, like the 1929-32 models for example, did not use a spring or the disc.
Top
#385203 - 03/06/17 11:38 PM Re: Distributor oiler [Re: Junkyard Dog]
m006840 Offline
Loc: merrimack nh
Thanks Gene and JunkYardDogJunkYardDog. The good news is that the grease was so hardened that the spring never contacted the shaft.
Top
#385206 - 03/07/17 12:07 AM Re: Distributor oiler [Re: m006840]
That is another problem with the spring....the grease tends to harden faster when the spring is in place since the grease doesn't flow all that well.
Top
#385219 - 03/07/17 02:04 AM Re: Distributor oiler [Re: Junkyard Dog]
Chev Nut Offline
Loc: West Allis,Wi.
The grease cup is supposed to be turned down a turn or two every 1000 miles when the chassis is greased. I refill the grease cp with fresh grease every few years.
Chevgene
Top
Moderator:  AntiqueMechanic, Coupefan
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
0 Chat Members (), 1 Guest and 36 Spiders or Bots online.
Key: Admin, Global Mod, Mod
We speak Chevy!
Time Flys!
Since 12/16/2001
Previous Photos
Newest Chat Registration
Shermy, CommanderSashi, Emanuel, DrDoug, ronp
14741 Registered Users
VCCA Info Links
NEWBIES START HERE
CHAT HELP
Send My Password
Kill My Chat Cookies
VCCA Home
G&D Calendar
Judging
Club Regions
Join Info
Forum Stats
14741 Chat Users
77 Forums
48874 Topics
Max Online: 304 @ 06/18/16 10:00 AM
See the USA
In your
Dinah says Hi!!
