1965 Chevrolet C10
My blinkers stopped working suddenly. Hmmn..
The hazards will flash on the driver side, but not the passenger side.
My flasher clicker thingy majingy(I always forget what the part is called) on the fuse panel sounds like it clicks once and stops... maybe it is just worn out and went ker-plunk. I'm going to replace it later today.
I also checked for voltage at the spot on the fuse panel where the blinker clicker thing plugs in and getting almsot 12v on one side so maybe it's just the clicker.
However, if it isn't, anything else I should check out?
-W
Check for a burned out signal bulb on the side that doesn't work. This is the most common cause for signals not to work on one side.
(edit/update : my truck has a 71 automatic steering column, so the hazards are wired to it's own flasher)
I checked out the front pass. side bulb and it looks clear.
The driver side will flash with the hazards.
I swapped out the flasher on the fuse panel and no change.
Hmmn.
-W
Might be the rear stop lamp as it lights with both the stop light switch, turn signal and hazard.
ok, so I checked each individual bulb for continuity, all is well.
I was checking something under the dash and I noticed part of the wiring harness was unplugged.
Hmnn... how did that happen and where does it go?
Oh. It goes to the steering column.
DOH.
laugh
I plugged in back up and all is well with the world.
I zip tied it together so it wouldn't slide apart again.
I supposed I unplugged it somehow while my big hands were routing wires and things around under the dash.
Thanks for all of the suggestions folks and happy wrenching.
-W
I would not like to try and guess the number of times I have done or heard of the same headache. Under dash work is the worst part of vehicle repairs.
It was this plug right here... somehow or another it was completely unplugged, I suppose because of my rooting around all under the dash tracing wires and double checking things.
I zip tied it together so that it would not come apart accidentally again.
willy
wiring harness plug / blinkers / 1965 chevy c10
-W
I agree.....what a pain! I will no longer work under a dash...if something needs to be done then I will get my daughter to do the work. She is smaller than I am and she can get up under the dash a lot easier!
Support The VCCA!
Member Photos
1964 Chevrolet Impala SS
by DreamChevy, February 17
My 1933 Chevy 2 Dr. Sedan
by 1939Chevy1, November 24
2 1927 Chevrolet Trucks
by 1927TRUCKS, June 7
Who's Online Now
1 members (the toolman), 67 guests, and 24 robots.
Key: Admin, Global Mod, Mod
Newest Members
Jayhicks, Tomvanhouten, Dads29Chevy, Tractorman, JEC51
18,307 Registered Users
Today's Birthdays
aristech, RalphL, tonysk
Forum Statistics
Topics59,069
Posts429,046
Members18,307
Most Online1,133
Jan 22nd, 2020
