Vintage Chevrolet Club Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
VISITORS: You are welcome to read our forums. If you want to participate FREE then you need to register. Join the VCCA and get access to the member-only features of the forum, including the ability to attach/upload photos. You'll also receive our monthly magazine "Generator & Distributor". Yearly membership as low as $25!
VCCA MEMBERS: Already a member? Great! Info to access the members-only area.
Topic Options
Rate This Topic
#384254 - 02/18/17 09:38 AM 1965 Chevrolet C10 - blinkers stopped working
Woogeroo Offline
Loc: Seeing the USA in my Chevrolet...
1965 Chevrolet C10
My blinkers stopped working suddenly. Hmmn..
The hazards will flash on the driver side, but not the passenger side.
My flasher clicker thingy majingy(I always forget what the part is called) on the fuse panel sounds like it clicks once and stops... maybe it is just worn out and went ker-plunk. I'm going to replace it later today.
I also checked for voltage at the spot on the fuse panel where the blinker clicker thing plugs in and getting almsot 12v on one side so maybe it's just the clicker.
However, if it isn't, anything else I should check out?
-W
Top
Vintage Auto Garage - 12 Volt
#384268 - 02/18/17 02:24 PM Re: 1965 Chevrolet C10 - blinkers stopped working [Re: Woogeroo]
Oldiron Offline
Loc: Alvaton, Kentucky, USA
Check for a burned out signal bulb on the side that doesn't work. This is the most common cause for signals not to work on one side.
Top
#384295 - 02/19/17 12:08 AM Re: 1965 Chevrolet C10 - blinkers stopped working [Re: Oldiron]
Woogeroo Offline
(edit/update : my truck has a 71 automatic steering column, so the hazards are wired to it's own flasher)
I checked out the front pass. side bulb and it looks clear.
The driver side will flash with the hazards.
I swapped out the flasher on the fuse panel and no change.
Hmmn.
-W
Top
#384296 - 02/19/17 12:20 AM Re: 1965 Chevrolet C10 - blinkers stopped working [Re: Woogeroo]
Chipper Offline
Loc: The Great State of TEXAS
Might be the rear stop lamp as it lights with both the stop light switch, turn signal and hazard.
_________________________
Top
#384309 - 02/19/17 05:30 AM Re: 1965 Chevrolet C10 - blinkers stopped working [Re: Chipper]
Woogeroo Offline
ok, so I checked each individual bulb for continuity, all is well.
I was checking something under the dash and I noticed part of the wiring harness was unplugged.
Hmnn... how did that happen and where does it go?
Oh. It goes to the steering column.
DOH.
laugh
I plugged in back up and all is well with the world.
I zip tied it together so it wouldn't slide apart again.
I supposed I unplugged it somehow while my big hands were routing wires and things around under the dash.
Thanks for all of the suggestions folks and happy wrenching.
-W
Top
#384312 - 02/19/17 10:55 AM Re: 1965 Chevrolet C10 - blinkers stopped working [Re: Woogeroo]
tonyw Offline
Loc: Goulburn Australia
I would not like to try and guess the number of times I have done or heard of the same headache. Under dash work is the worst part of vehicle repairs.
Top
#384359 - 02/20/17 10:44 AM Re: 1965 Chevrolet C10 - blinkers stopped working [Re: Woogeroo]
Woogeroo Offline
It was this plug right here... somehow or another it was completely unplugged, I suppose because of my rooting around all under the dash tracing wires and double checking things.
I zip tied it together so that it would not come apart accidentally again.
willy
wiring harness plug / blinkers / 1965 chevy c10
-W
Edited by Woogeroo (02/20/17 10:44 AM)
Top
#386122 - 03/22/17 02:25 AM Re: 1965 Chevrolet C10 - blinkers stopped working [Re: tonyw]
Junkyard Dog Offline
Loc: Eagle Point, Oregon
I agree.....what a pain! I will no longer work under a dash...if something needs to be done then I will get my daughter to do the work. She is smaller than I am and she can get up under the dash a lot easier!
Top
Moderator:  AntiqueMechanic, d2d2
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
1 Chat Members (Peter_Gariepy), 0 Lookie Loo's and 32 Spiders or Bots online.
Key: Admin, Global Mod, Mod
Today's Birthdays
32confederate
Helpful Links
Forum Registration
New User Forum
Members Only Forum
Reset Your Password
Kill Your Cookies
VCCA Home
Join the VCCA
Member Photos
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
1936 Roadster - S. Africa
Chevy on the Levee
'37 Seat
Forum Stats
15086 Chat Users
79 Forums
50178 Topics
Max Online: 304 @ 06/18/16 10:00 AM
