The Surgeon General has determined that excessive concern about your health
... may be hazardous to your health.
Today's Birthdays
32confederate, EdLo, ewv715, galen33, Paul Boyd
Featured Chat Guy (or Gal)
VCCA Member Photos
Getting ready for the 4th of July Parade
Interesting Delivery
32' Oldsmobile Dovetail Receptacle
32 Special Bracket ID
Chevrolet Trim Plate
Pilot Bushing Removal Tool artile
VCCA Member Projects
53rd installment - '28 engine tear down
52nd installment - '28 engine tear down
51st installment - '28 engine tear down
50th installment - '28 engine tear down
49th installment - '28 engine tear down
Topic Options
Rate This Topic
#383848 - 02/12/17 06:53 PM 1926 Chevy Firetruck in Oroville, CA $1800
Rustoholic Offline
Loc: San Leandro, CA
Hi all,
I noticed this on the local craigslist. I suspect someone had a dead firetruck and mounted the bed and front water pump on a '26 Chevy 1 ton truck.
Here is a link to the ad: 1926 Chevy Firetruck
Mike Quezada checked it out and here are his comments:
1. The truck is suppose to be a 26 but it has a 28 engine and a 3 speed transmission. The chevy 3 speed transmission was free to shift.
2. Mounted directly behind the 3 speed transmission is a Muncie gear box. The gear box appears to be installed with the proper adapters to connect the 3 speed chevy to the Muncie. The muncie unit did not shift.
Muncie made two types of transmissions for early fords and chevys. The larger one with power take off plate was for trucks only while the smaller was used in cars also. Both are 3 speed with reverse, the speeds being roughly 2 to 1 underdrive, direct, and 1 to 1.4 overdrive. It is possibly the truck has a transmission from some other vehicle adapted into it. Bearings and bushings are readily available. I did not see a power take-off on this unit.
3. The original drive line is attached to the rear of the Muncie gear box. The gear box is approximately 12 long and the frame of the truck was cut and extended that same amount.
4. There is no PTO from either of the transmissions.
5. The front water pump appears to be lined up directly to the crank on the front of the engine (drive line missing)
6. I could not get the motor to turn by hand. The engine had a electric fuel pump attached to the cowl. It has the shape of a hydraulic brake reservoir. The engine had a non-stock carburetor. The engine has a very large alternator, attached to a rectifier that was feeding a voltage regulator putting out 7 volts at 100 amps'
7. The rear driver rim is damaged, when they were filling the tire they forgot and left the air compressor running until the rim exploded, this rim can not be repaired.
8. The tires are all in good shape but are aged.
9. The rear fire box does not appear to be fitted for this truck. The wheel well is much larger than is needed for the standard Chevrolet tires. There is only 1 - 1 1/2 gap between the rear tires and the fire box frame.
_________________________
Top
#383861 - 02/12/17 08:53 PM Re: 1926 Chevy Firetruck in Oroville, CA $1800 [Re: Rustoholic]
Rustoholic Offline
If interested, call Danny at (510) 227-4516.
Top
#391502 - 06/30/17 01:57 AM Re: 1926 Chevy Firetruck in Oroville, CA $1800 [Re: Rustoholic]
Rustoholic Offline
The price has been reduced to $1000.
Here's the current ad: https://sfbay.craigslist.org/eby/atq/6195192531.html
Top
Moderator:  Chevykid
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
0 Chat Members (), 1 Guest and 36 Spiders or Bots online.
Key: Admin, Global Mod, Mod
We speak Chevy!
Time Flys!
Since 12/16/2001
Previous Photos
Newest Chat Registration
Shermy, CommanderSashi, Emanuel, DrDoug, ronp
14741 Registered Users
VCCA Info Links
NEWBIES START HERE
CHAT HELP
Send My Password
Kill My Chat Cookies
VCCA Home
G&D Calendar
Judging
Club Regions
Join Info
Forum Stats
14741 Chat Users
77 Forums
48874 Topics
Max Online: 304 @ 06/18/16 10:00 AM
See the USA
In your
Dinah says Hi!!
