Posts: 1 |
Does anyone know what the part is called that the clutch linkage rod connects to? Its pressed onto the shaft that comes through the frame and then the clutch linkage rod connects to it.
Jones
Are you refering to the shaft that is between the frame on the out side and the bell housing on the inside (engine bracket if a 6 cyl.)? It has two levers sticking out-The rod from the clutch pedal connects to one and the other is connected to the clutch fork.---If so it is called the clutch bell crank
