Posts: 1,004 Likes: 5
Posts: 1,004 Likes: 5 |
When my car was being painted, some over spray got under the tarp covering the engine and onto the new spark plug wires. I believe these original style wires have a clear lacquer finish. What is the best way to clean off the paint? If I use lacquer thinner, does that remove the clear coating on the outside? Any suggestions would be appreciated. Thanks
Posts: 292 |
Using LQ thinner used sparingly should be fine Al
Posts: 30,699 Likes: 141
Posts: 30,699 Likes: 141 |
I would say the lacquer thinner could remove the lacquer coating. Are you sure the car wwas repainted with lacquer?
Posts: 1,125 |
If you are unable to remove the overspray, the wires can be repainted. Sid
Posts: 1,019 Likes: 3
Posts: 1,019 Likes: 3 |
Hello a3alf,
Would mineral spirits work ? I have seen it used as a cleaner for paint brushes.
The over spray came through the firewall when the lower half of the dash was painted - a light gray. The paint is a single stage polyurethane. I have sent an e-mail to the place I purchased the wire set to see if they can tell me how to remove the over spray WITHOUT damaging the wire set.
Posts: 7,471 Likes: 25
Posts: 7,471 Likes: 25 |
Have you checked with the painter or a paint supplier?
I have not heard back from Chevs of the 40's where I purchased the wires from. The paint suppler did not want to commit to any remover (too many lawyers in this world I guess). I used some Brakleen on a small spot and it took off the overspray. When the weather gets warmer, I plan on cleaning all the wires and re-applying the clear outer coating. If the wires fail, I will do what I had to do in the past - buy another set.
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
HE, Merely order an new set of wires. Put the old ones in a plastic shopping bag and toss them in the trunk or wherever. Problem solved. You're welcome, Charlie
I used some rubbing compound and it took the over spray right off without removing the gloss lacquer finish.
1 members (the toolman),
67
guests, and
24
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,069
Posts429,046
Members18,307
