Posts: 934 |
Hello, does anyone know where the heater switch mounts to under the dash? I bought a new switch and need to know where to mount it, Thanks in advance...Oscar The Grouch
OSCAR ALBRETSEN
The switch mounts just to the right of the defroster cable.There should be a hole in the lower flange of the dash.The correct switch is a flipper (lever) type switch on will say "AIR" on the switch....The car switch says "HEAT" and that will work also.
Posts: 934 |
Thank you Chevgene...Oscar :cool2:
OSCAR ALBRETSEN
