I didn't know where to stick this because I didn't want to cover some more importand and appropriate post at some other forum.
This is for our shut-in friends up North. To give them some thing to think about whilst they're sitting around the fire between trips to the woodshed to get yet another turn of wood. With thier cars winterized, roads closed, below freezing outside what in the world do they have to do? This should help:
Question One: We all know that the drive-train furnishes the power for the car to move down the road but do we know if the car is being pushed or pulled? While the drive-train moves itself forward by the traction of the rear wheels (just one at a time) but where soes the car's body get its push or pull? Hmmm. Read on.
It seems to me that the car's body is pushed along with the chassis and front end by the rear springs that are attached at the forward position via the spring eye bushings. Owing to the fact that the rear of the springs are henged it couldn't be there, could it.
Think about my analysis and solution to this question and see iff you agree with me.
Question Two:
How many of the teeth in the ring gear are being presueized at a time. That is, as the pinion gear thrns against the ring gear how man teeth of each are action upon at a time. I say just one. What do you think?
Questiion Three:
What is the optimum operating temperture of our old 207/216 engines? I would say 180 degrees farenhieght. What do you say?
Question Four:
If you changed your oil on the old 207 or 216 and the only oil you culd get was 20 weight or 40 weight, what would your choice be? (Why?
Forget about the weather for this one. Let's say it is summer time where ever you are in the continential USA.) And, that the oil change is merely temporary)
Question Five: (your modern car)
Does it do any good to crank the temperture setting all the way up when the car is cold? In other words if you want it to be a plesent 72 degrees inside does it do any good to crank it up to 85 or so? If you know the answer to this one it will help me convience either me or my wife.
Charlie
