A penny saved
... is ridiculous.
Today's Birthdays
32confederate, EdLo, ewv715, galen33, Paul Boyd
Featured Chat Guy (or Gal)
VCCA Member Photos
Getting ready for the 4th of July Parade
Interesting Delivery
32' Oldsmobile Dovetail Receptacle
32 Special Bracket ID
Chevrolet Trim Plate
Pilot Bushing Removal Tool artile
VCCA Member Projects
53rd installment - '28 engine tear down
52nd installment - '28 engine tear down
51st installment - '28 engine tear down
50th installment - '28 engine tear down
49th installment - '28 engine tear down
Topic Options
Rate This Topic
#379837 - 12/05/16 06:28 PM Hooter on 25 Superior
danie Offline
Loc: Northern Cape
Can any one supply me of photo of the piece of spring metal that is supposed to make the noise when motor of hooter is turning. Mine is missing ans want to make one
Top
Vintage Auto Garage - 6 Volt
#380388 - 12/15/16 11:39 AM Re: Hooter on 25 Superior [Re: danie]
Rusty_Relic Offline
Loc: Griffith NSW Australia
Hmmmmm.
Not too sure what you are after. I presume you are referring to the diaphragm of a Claxon type horn which have an electric motor that spins with a small star wheel attached to the spindle. The raised serrations on the face of the star wheel rub against a metal tooth protruding from the centre boss of the diaphragm which is made from thin (approx .020") very springy steel. The tone of the horn is adjusted by increasing or decreasing the pressure with which the two parts meet. (adjusting screw on back of horn and slightly moves the motor armature forward or back).
Swap meets are usually scattered with incomplete horns of all breeds, and it is just a matter of getting one that will fit/adapt to your situation. I have found not too heavily rusted (pitted) diaphragms work OK when cleaned up, but do not paint it as this acts like a dampener. Not sure what the best protective coating would be, maybe a very light coat of etch primer (clear watery type). The diaphragm is fitted each side with a thin paper gasket approx 1/2" wide,where it clamps between the horn funnel and motor housing.
Earlier '25 Superiors had an inferior Remy vibrator type horn protruding through a hole in the firewall, and make quite a different sound, more like a frog burping, and feeble at that!
Sorry I can't oblige with photos. All too much stuffing around for my intellect to fathom.
Cheers.
Top
#380526 - 12/18/16 01:05 AM Re: Hooter on 25 Superior [Re: Rusty_Relic]
danie Offline
Loc: Northern Cape
Thanks Rusty. Not sure what the diaphragm should look like.
Top
#380667 - 12/21/16 12:59 PM Re: Hooter on 25 Superior [Re: danie]
Rusty_Relic Offline
Sorry. Upside down english!
About 3 1/2" diam spring steel disc with 5-6 holes around the outside that align with the matching holes in the motor body and horn funnel. The disc diameter needs to match that of the flange and body where the two mate up with each other. The disc is clamped between the two with a gasket each side. It is about the same size and appearance of a fuel pump diaphragm, except made of spring steel.The design/size of the small lug boss in the centre of the disc that engages with the motor armature varies with models/ brands.
If still not clear, email me and I should be able to get you a picture that way.
Geoff.
Top
#381768 - 01/11/17 06:36 PM Re: Hooter on 25 Superior [Re: Rusty_Relic]
danie Offline
Loc: Northern Cape
Got it flicked. Makes good noise
Top
Moderator:  AntiqueMechanic, Coupefan
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
0 Chat Members (), 1 Guest and 36 Spiders or Bots online.
Key: Admin, Global Mod, Mod
We speak Chevy!
Time Flys!
Since 12/16/2001
Previous Photos
Newest Chat Registration
Shermy, CommanderSashi, Emanuel, DrDoug, ronp
14741 Registered Users
VCCA Info Links
NEWBIES START HERE
CHAT HELP
Send My Password
Kill My Chat Cookies
VCCA Home
G&D Calendar
Judging
Club Regions
Join Info
Forum Stats
14741 Chat Users
77 Forums
48874 Topics
Max Online: 304 @ 06/18/16 10:00 AM
See the USA
In your
Dinah says Hi!!
