Posts: 139 |
Anyone have experience with replacing the wire lead that goes to the coil for a 34 master electrolock? Is it as simple as prying the three tabs apart on the lock cylinder housing and separating the unit to access the wire?
Chuck
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Yes. The Filling Station sells a rebuild manual for the 37-39 models. It may be of use to you. I don't know how similar they are to yours. It sounds like the key end may be the same.
Posts: 1,884 Likes: 12
Posts: 1,884 Likes: 12 |
You can access the wire that way but you may have to drill the complete wire from the cable to replace it.
Jon T.
