Posts: 402 |
I was looking at purchasing a spare transmission for my 32 and came across one for a 33. Both have the free wheeling unit so I was wondering if there is any other differences? Dose anyone know the correct part number on the side of the case for a 33?
The parts book shows the case as being the same from 1932-1936 with syncromesh. (that would exclude Standards). As far as the gears go they have different part umbers due to a slight ratio change in 1933. Also the early 1932 had all straight cut gears (very noisey 2nd gear) and late had helical gears (silent 2nd). From what I find the comp;ete 1933 transmission will fit a 1932 as any differences is i the gears only. The advantage would be if you ever needed a gear the 1933 (and up) style would be easier to find than the two differnt selection of gears found in 1932 only.
The low gear ratio in 1932 was 3.17 to 1. iN 1933 3.08. iN 1932 2ND GEAR WAS 1.82 TO 1 AND IN 1933 1.70 TO 1. aLSO THE SYNCRONIZING CONE CHANGED IN SIZE SLIGHTLY.
Posts: 402 |
I must have the early transmission in my 32 as second gear has the whine. What number would be on the case to identify the transmission on being from a 33.
The case casting number would be the same from 1932-1936. There should be a date code in rasied letters like 8 03 or so on the case. It has to be from a 1932 or 1933 due to having freewheeling. Other wise you can remove the top cover and count the number of teeth on th e cluster gear. The '32 will have 24-13-20 and the '33 25-13-21.
Posts: 402 |
Did all 33s have free wheeling?
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
All 1933 passenger transmissions had freewheeling. The 1/2 ton trucks had the same transmission without freewheeling.
Posts: 402 |
This all really great information. Thanks again Guys
Just a note the 1933 Standard had a non-syncronized smaller transmission without freewheeling. I believe you could install a 1934-1936 Master transmission in a 1933 and eleminate the freewheeling.
Thanks Gene for making the correction. I wasn't thinking about the '33 Standard. Sorry Joe, it is not the first thing I think of with '33s. So my post should have been "All '33 Master/Eagle passenger transmissions would have freewheeling. The '33 1/2 ton trucks had the same transmission without freewheeling."
For some reason (like low production) the 1933 Standard is like a forgotten cousin. I forgot about the truck also.
Posts: 3,163 |
No problem guys. I'm used to owning the "unknown" Chevrolets...Joe
You have to give Chevrolet credit. The Standard had a slow start in 1933 and was a good seller by 1935 when it looked almost obsolete compared to many 1935 cars.
