Posts: 509 |
I have a short, 1/2 inch long crack or hole in the side of my block, between the carb and generator about 3 inches from the head. I'm considering cleaning and welding it. Any thoughts about this?
If I have to replace the block, may as well rebuild the replacement, and then restore the whole car. That will take years on my budget.
Posts: 3,511 Likes: 47
Posts: 3,511 Likes: 47 |
FYI, here is a link to a similar discussion: What to do with a cracked block? Cheers, Dean
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
You might be able to seal it with one of the newer specialty epoxies seeing that it is so small.
Posts: 1,255 Likes: 10
Posts: 1,255 Likes: 10 |
Other people have used the threaded rod method to "stitch" the crack shut. Since there is no pressure on the water jacket, or the crankcase it should work. There was a tech article on it in the G & D a few years ago. Check it out.
