I am trying to assist another gentleman get his '37 1/2 ton back on the road. The transmission that was pulled out of the truck has casting number 590874 on it. A 3 speed car transmission in a truck?
I took one of my spare 4 speeds to the shop working on his truck and they are claiming that they can't get the transmission into the truck. Something about the input shaft being different.
Is there anyone more familiar with the car running gear that can help us sort out what we need to do to put a 4 speed back into this truck?
Does anyone have a 3 speed they are looking to part with?
Thanks for the help,
~Justin
Grandad's 1937 Chevy 1/2 ton
"Wylburr Clyde"
Pictures of Clyde
I have learned something new. Apparently, that casting number is not for a car but actually for the truck. Can someone confirm this for me?
What is casting 590874 used for?
Thanks,
~Justin
"Wylburr Clyde"
Pictures of Clyde
Yes that is correct for 1937-39 trucks.
Thank you,
Is it possible to put in a 4 speed (from the same era) where a three speed once was?
Justin
~Justin
"Wylburr Clyde"
Pictures of Clyde
The 3 and 4 speed truck transmissions have a different bolt patterns going onto the bellhousing. A car 3 speed will not bolt up to a truck bellhousing
Gene,
According to the '37 Service Manual the 3 speed truck and 4 speed truck transmission were interchangeable except for the speedo gear.
https://drive.google.com/open?id=0BwpjuqQnrSned2Z0bjdCX3RNTzg
Am I reading this incorrectly?
Justin
~Justin
"Wylburr Clyde"
Pictures of Clyde
...Yes...
How should this be read?
~Justin
"Wylburr Clyde"
Pictures of Clyde
Sorry, thought it said correctly. The truck 3 speed and 4 speed are interchanable. Car 3 speed is not.
When the truck 3 speed in used to replace a truck 4 speed the 4 speed spedometer gears are different from the 3 speed as is the mount bracket.
I have the 3 speed originally out of my 1/2 ton and the 4 speed out of a 39 1/2 ton and I noticed the slip joint/universal joint are different. 1 has a bush at the very front of the drive tube supporting the rear section of the universal joint and another more rearward supporting the driveshaft while the other gearbox the front bush is more rearward and runs on the driveshaft only. I must admit the 4 speed had a heavier differential behind it so that may have made some difference. Both boxes appear to be the same length and I think the same universal ball but I havent looked at speedo drive.
