Vintage Chevrolet Club Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
VISITORS: You are welcome to read our forums. If you want to participate FREE then you need to register. Join the VCCA and get access to the member-only features of the forum, including the ability to attach/upload photos. You'll also receive our monthly magazine "Generator & Distributor". Yearly membership as low as $25!
VCCA MEMBERS: Already a member? Great! Info to access the members-only area.
Page 2 of 2 < 1 2
Topic Options
Rate This Topic
#383945 - 02/13/17 11:34 PM Re: 1931 6V brake light bulb [Re: a3alf]
6wheel Offline
1000
Loc: Mississippi
As I said previously, the tail light assemblies are reproduction. Considering Al's comment, I shortened the mounting brackets for the bulb sockets to make sure the bulbs couldn't hit the inside of the tail light buckets. I then replaced the bulbs for the fifth time in about 4 months. Since then I have driven the car about 15 miles, and neither bulb has blown. Looks like the problem is solved.
Thanks guys for all of your thoughts.
Sid
Top
Vintage Auto Garage - 6 Volt
#387471 - 04/12/17 03:00 PM Re: 1931 6V brake light bulb [Re: 6wheel]
6wheel Offline
1000
Loc: Mississippi
It happened again! I checked the brake lights and found that both rear bulbs were blown again. Could this be caused by the turn signal switch? I didn't use this switch for a few years while showing the car. I wanted it to look all original, so I hid the switch under the dash. This problem started since I mounted the switch on the column and began using it.
Sid
Top
#387492 - 04/12/17 08:09 PM Re: 1931 6V brake light bulb [Re: 6wheel]
Junkyard Dog Offline
Loc: Eagle Point, Oregon
Disconnect the turn signal switch and see what happens. If the bulbs don't blow when the turn signal switch is disconnected then you found your problem.
_________________________
Top
#387828 - 04/17/17 02:56 PM Re: 1931 6V brake light bulb [Re: Junkyard Dog]
6wheel Offline
1000
Loc: Mississippi
Thanks Dog. We will see.
Top
#387831 - 04/17/17 02:59 PM Re: 1931 6V brake light bulb [Re: 6wheel]
Let us know what happens.
Top
#389970 - 05/30/17 06:54 PM Re: 1931 6V brake light bulb [Re: Junkyard Dog]
6wheel Offline
1000
Loc: Mississippi
I found the wire for right rear was loose in the turn signal switch. I re-soldered it and reassembled the switch. Hopefully, this will solve problem.
Thanks,
Sid
Top
Page 2 of 2 < 1 2
Moderator:  AntiqueMechanic, Coupefan
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
1 Chat Members (Peter_Gariepy), 1 Guest and 28 Spiders or Bots online.
Key: Admin, Global Mod, Mod
Today's Birthdays
32confederate
Helpful Links
Forum Registration
New User Forum
Members Only Forum
Reset Your Password
Kill Your Cookies
VCCA Home
Join the VCCA
Member Photos
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
1936 Roadster - S. Africa
Chevy on the Levee
'37 Seat
Forum Stats
15086 Chat Users
79 Forums
50178 Topics
Max Online: 304 @ 06/18/16 10:00 AM
