Me and my wife lived happily for twenty years....
... then we met.
Today's Birthdays
32confederate, EdLo, ewv715, galen33, Paul Boyd
Featured Chat Guy (or Gal)
VCCA Member Photos
Getting ready for the 4th of July Parade
Interesting Delivery
32' Oldsmobile Dovetail Receptacle
32 Special Bracket ID
Chevrolet Trim Plate
Pilot Bushing Removal Tool artile
VCCA Member Projects
53rd installment - '28 engine tear down
52nd installment - '28 engine tear down
51st installment - '28 engine tear down
50th installment - '28 engine tear down
49th installment - '28 engine tear down
Page 1 of 2 1 2 >
Topic Options
Rate This Topic
#374976 - 09/07/16 07:49 PM 1931 6V brake light bulb
6wheel Offline
1000
Loc: Mississippi
In the last month I have replaced both #87 brake light bulbs twice in my '31 coupe. I've only driven about 30 miles since I replaced them last time. I just happened to check and found they were out again today. The ones that blew were GE, and I replaced this time with Wagner. I'm using YnZ's turn signal kit which is part of my harness. The front signal lights are in the cowl lights. The bulbs in the cowl lights have not blown in the 8 years the car has been restored. Any thoughts?
Sid
Top
Vintage Auto Garage - 6 Volt
#374980 - 09/07/16 08:50 PM Re: 1931 6V brake light bulb [Re: 6wheel]
Junkyard Dog Offline
Loc: Eagle Point, Oregon
Check for a bad ground, bad light sockets or a short in the wiring.
_________________________
Top
#375082 - 09/08/16 07:03 PM Re: 1931 6V brake light bulb [Re: Junkyard Dog]
6wheel Offline
1000
Loc: Mississippi
Sockets and ground checked out okay, but generator is putting out 10 volts. Will try to adj third brush. Thanks
Sid
Top
#375086 - 09/08/16 07:47 PM Re: 1931 6V brake light bulb [Re: 6wheel]
6wheel Offline
1000
Loc: Mississippi
Finally figured out how to move brush. Generator now putting out 7.8 volts max. Hopefully, this will stop bulb blowing. I don't know how to secure brush. The screw on back of generator is tied to a bracket inside, but the bracket is no where near the new location of the brush.
Sid
Top
#375091 - 09/08/16 08:57 PM Re: 1931 6V brake light bulb [Re: 6wheel]
Bill Barker Offline
Previous ChatMaster
Loc: Issaquah, WA
Instructions are Available HERE.
REMEMBER: Move DOWN to go UP. And UP to go DOWN.
(Move brush DOWN to Increase Voltage, and brush UP to lower voltage.)
Top
#375110 - 09/09/16 01:41 AM Re: 1931 6V brake light bulb [Re: Bill Barker]
6wheel Offline
1000
Loc: Mississippi
Thanks Bill, I'd seen similar picture in manual. I guess I need to study that part of the generator more closely. I moved the brush by using a screw driver like a pry bar. The screw shown in the picture on the back of the generator fastens a small plate on the inside, but it doesn't appear to attach to anything.
Sid
Top
#375111 - 09/09/16 01:58 AM Re: 1931 6V brake light bulb [Re: 6wheel]
The plate doesn't "attach" to anything...instead it holds pressure on the third brush bracket so that the third brush doesn't move after the screw on the end frame is tightened down. Check inside of the generator to make sure that the plate is on top of the third brush bracket to hold it in place.
Top
#375421 - 09/14/16 05:24 PM Re: 1931 6V brake light bulb [Re: Junkyard Dog]
6wheel Offline
1000
Loc: Mississippi
I found a spare generator in the attic. Its third brush has a bronze bracket that is secured by the clamp like the Dog days. The third brush on the generator on my 31 does not have this bronze bracket, or maybe not all of it. It seems very secure without being tied down. I had to move it by prying with a screw driver, and after driving 20 miles yesterday, it hasn't moved. The lower voltage is a good thing too. So far no more blown bulbs. Thanks guys.
Sid
Top
#380320 - 12/14/16 06:58 PM Re: 1931 6V brake light bulb [Re: 6wheel]
6wheel Offline
1000
Loc: Mississippi
I've driven the '31 about 150 miles in the last few months, and I noticed after a short drive that it was making about 7 amps at idle. Checked the stop light bulbs and found that both were blown again. I plan to have my spare generator checked out, and if it's okay I'll run it, since it's third brush appears to be complete.
Top
#380323 - 12/14/16 08:08 PM Re: 1931 6V brake light bulb [Re: 6wheel]
Chev Nut Offline
Loc: West Allis,Wi.
The amps will not blow the bulbs. Too many volts will do that.
Chevgene
Top
#380324 - 12/14/16 08:11 PM Re: 1931 6V brake light bulb [Re: Chev Nut]
6wheel Offline
1000
Loc: Mississippi
Thanks Gene. I'll check the generator output again. I presume the third brush has slipped again.
Sid
Top
#380330 - 12/14/16 09:19 PM Re: 1931 6V brake light bulb [Re: 6wheel]
If the clamp for the third brush is tightened down correctly the third brush should not slip.
Top
#380332 - 12/14/16 09:20 PM Re: 1931 6V brake light bulb [Re: 6wheel]
Chev Nut Offline
Loc: West Allis,Wi.
Check the voltage, Run engine for about 20 minutes at least fast idle) and it sould be around 7.5 volts.
Chevgene
Top
#380735 - 12/22/16 08:22 PM Re: 1931 6V brake light bulb [Re: Chev Nut]
6wheel Offline
1000
Loc: Mississippi
Generator output is still 7.5 volts. What else could blow bulbs? The bulbs fit very tightly in the reproduction taillight buckets. Maybe they are hitting the inside of the bucket as the car bounces. Also,every bulb I have used is made in China...am I the only one with this problem? I found 2 new bulbs in my stash with blown filaments. As another test I have a new working 87 brake light bulb in the left taillight bucket. We will see how long it lasts.
Thanks,
Sid
Top
#380779 - 12/23/16 04:35 AM Re: 1931 6V brake light bulb [Re: 6wheel]
Bulbs made in China are junk.
The generator output of 7.5 volts is perfect.
Edited by Junkyard Dog (12/23/16 04:35 AM)
Top
#380898 - 12/24/16 09:45 PM Re: 1931 6V brake light bulb [Re: 6wheel]
Tiny Online
Loc: South Central Kansas
Some China stuff is OK but most is junk. I bought a dozen 2530 headlight bulbs that were made in China. The low beam would burn out within 5 seconds. The high beam would last a while. I threw them away and bought two dozen NOS bulbs I found on ebay. If it were me I'd put another Chinese in, lay a brick on the brake pedal, pull up my chair & see if they do the same thing. Watch them for 20-30 minutes without driving the car. See if they simply burn out like the junk ones I bought. Does the inside of the glass have the typical burn mark a burned out bulb makes? For what it's worth I've had pretty good luck with Chinese Wagner bulbs.
Edited by Tiny (12/24/16 09:53 PM)
Top
#381650 - 01/09/17 08:16 PM Re: 1931 6V brake light bulb [Re: Tiny]
6wheel Offline
1000
Loc: Mississippi
I ran the car at fast idle with left turn signal on the entire time. Bulb did not blow. Will continue to watch.
Thanks, Sid
Top
#382280 - 01/19/17 05:44 PM Re: 1931 6V brake light bulb [Re: 6wheel]
6wheel Offline
1000
Loc: Mississippi
Put new bulb in right side and drove car about 5 miles. Checked bulbs when I got home...both brake light bulbs where blown. There was no discoloration. The filament just had a short section missing. Installed new bulbs in both buckets. One is GE, other is Wagner. I also moved the sockets so that the glass part of the bulbs couldn't touch the bucket.
Top
#382345 - 01/20/17 03:25 PM Re: 1931 6V brake light bulb [Re: 6wheel]
6wheel Offline
1000
Loc: Mississippi
I tested it running in the garage for 30 minutes. I left the brake lights on for 15 minutes, flashed the brake lights for 5 minutes, and flashed the left and right blinkers for 5 minutes each. I also tapped on each tailight bucket several times. Both bulbs continued to burn. I'll test drive it when the weather breaks.
Sid
Top
#382349 - 01/20/17 03:31 PM Re: 1931 6V brake light bulb [Re: 6wheel]
Is that at idle? If so, what is the generator output at speed when driving?
Top
#382351 - 01/20/17 04:20 PM Re: 1931 6V brake light bulb [Re: Junkyard Dog]
6wheel Offline
1000
Loc: Mississippi
It was at fast idle, and output was 7.5 volts.
Top
#382353 - 01/20/17 04:30 PM Re: 1931 6V brake light bulb [Re: 6wheel]
What is the output while driving at speed?? The output might be too high which would cause the bulbs to blow while you are driving.
Top
#382354 - 01/20/17 04:43 PM Re: 1931 6V brake light bulb [Re: Junkyard Dog]
6wheel Offline
1000
Loc: Mississippi
Thanks Dog. I'll check voltage at higher RPM.
Top
#382367 - 01/20/17 07:46 PM Re: 1931 6V brake light bulb [Re: 6wheel]
6wheel Offline
1000
Loc: Mississippi
Output voltage at high RPM is 7.85. I just test drove it for about 3 miles. Checked bulbs halfway and they were good. Drove rest of way home and they were both blown! Could the brake light switch do this? It is old, but works. The turn signal switch came with the harness from YNZ.
Sid
Top
#382370 - 01/20/17 08:04 PM Re: 1931 6V brake light bulb [Re: 6wheel]
a3alf Offline
Loc: New York
If there is no burn marks and the filament is broken then the bulb is hitting something when driving.
Al
Top
Page 1 of 2 1 2 >
Moderator:  AntiqueMechanic, Coupefan
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
0 Chat Members (), 1 Guest and 36 Spiders or Bots online.
Key: Admin, Global Mod, Mod
We speak Chevy!
Time Flys!
Since 12/16/2001
Previous Photos
Newest Chat Registration
Shermy, CommanderSashi, Emanuel, DrDoug, ronp
14741 Registered Users
VCCA Info Links
NEWBIES START HERE
CHAT HELP
Send My Password
Kill My Chat Cookies
VCCA Home
G&D Calendar
Judging
Club Regions
Join Info
Forum Stats
14741 Chat Users
77 Forums
48874 Topics
Max Online: 304 @ 06/18/16 10:00 AM
See the USA
In your
Dinah says Hi!!
