Posts: 19 |
Greetings, Im stuck. Can someone help me with a power steering bracket problem? I have a extended water pump and a lower PS pump bracket that fits, but cannot seem to get the upper bracket. Any advice with a part # or other suggestion. Thanks
Posts: 3,163 |
Are you using the 1969 & up brackets? It kind of sounds like you don't have the 68 brackets. What body style also?...Joe
