Hello all,
Last year I was going to replace my transmission mount. But before I did that I replaced the transmission case to rear bearing support gasket, the rear bearing support to ball retainer collar gasket, all of these I installed with the black gaskt adhesive. I also replaced the ball to ball retainer collar gasket or packing, (it's gray round and thick). Now that I did all of this I refilled with gear lubricant and I decided to wait and see if I had any leaks in the system. It leaked from every location! The gaskets were purchased from NAPA and were a grayish blue color. I torqued down the bolts, but not so much that I would have warped the housing. What am I doing wrong? Should I use a different type of cement, maybe no cement at all? What about different suppliers of gaskets, (although I believe the fault lies in me)!
Also I have just fininshed taking the rear end off the car. Since the torque tube is readily accessible, is there anyway to check to see if the propeller shaft bushing and seal need to be replaced? There is a business in Tampa that specializes in drive shafts. Looking in the Chevy repair manual It looks a bit complicated. How can you tell if the bushing and oil seal are still good?
Thanks for everyone's help!!
51Steve
