Page 4 of 4 1 2 3 4
yipp Let's hope that is the final time you have to tear down for many many years
dick
Cousin Dave and I did finally get everything sorted out and the engine is back in the car and sounds great. We put about 5 miles on the car before the Christmas holidays and everything seems to be good! Still have the hood to put back on the car before I can say we've finished the job.
Dale Carter
VCCA #8661
1948 Fleetmaster Convertible
1948 RHD Stylemaster Sedan Delivery
1948 1-Ton Tow Truck
1967 Camaro Coupe
Dave how about so pic's...Make sure you include the engine bay with that new fresh 216!!!
Thanks for the Dale & Dave story. Very interesting. I'll look forward to seeing the car on the Six Cylinder Tour in Michigan.
Joined VCCA June 1, 1961
Absolutely!! Looking forward to driving it this summer to the Central Meet and Six Cylinder Tour.
Dale Carter
VCCA #8661
1967 Camaro Coupe
Great to hear! I'll bring my trailer just in case though...
Question about the picture of your engine: I installed my glass bowl fuel pump, then took the chassis to my painter. He had 3-4 Ford guys in the shop, and they all asked why I had the fuel pump on upside down. They said the sediment is to settle in the bottom of the glass bowl, and running it the way we have it will just plug it. Is that right, or should I just stop listening to Ford guys??
I've never seen one installed upside down! All the photos I've seen of engines have the bowl upright. Gene??
Dale Carter
VCCA #8661
1967 Camaro Coupe
Yes, the glass bowl is on top. The gas "comes and goes" at a higher level so there is room for dirt on the bottom. It is a filter bowl (the glass). The 1929-1936 (except 1934) was the other way around, had no filter, and it acted as a sediment bowl.
That must explain it... They were model T and A guys! Thanks, Gene. I really didn't want to play with it!
Page 4 of 4 1 2 3 4
