Vintage Chevrolet Club Forums
A nonprofit organization dedicated to the preservation, restoration and enjoyment of all Chevrolets and GMCs.
VISITORS: You are welcome to read our forums. If you want to participate FREE then you need to register. Join the VCCA and get access to the member-only features of the forum, including the ability to attach/upload photos. You'll also receive our monthly magazine "Generator & Distributor". Yearly membership as low as $25!
VCCA MEMBERS: Already a member? Great! Info to access the members-only area.
Page 2 of 2 < 1 2
Topic Options
Rate This Topic
#341445 - 04/28/15 03:09 AM Re: 235 distributors [Re: junkyardjeff]
bobg1951chevy Offline
Loc: Hendersonville, N.C.
#2 cylinder ..... somewhere in one of your threads, I recall you mentioning ( I think ) that #2 was a sleeved cylinder. Is that correct ?
Thinking, even if it was a sleeved cylinder, I cannot recall having a sleeve create an "engine noise concern".
I have driven I 75 to I 71 to get to northern Ohio so many times ( family is in Mentor, Ohio ), certainly would give that 235 a listen, but I have no immediate plan to get to Ohio real soon.
_________________________
1951 Chevy Styleline Deluxe 2 door sedan. Purchased in 2000.
1951 Chevy Styleline Deluxe Sport Coupe. Purchased in 2014.
1969 Chevy Corvair 500 Coupe. Purchased in 2017.
Top
Vintage Auto Garage - 12 Volt
#341458 - 04/28/15 01:01 PM Re: 235 distributors [Re: bobg1951chevy]
junkyardjeff Offline
1000
Loc: Dayton Ohio
I am thinking #2 was sleeved but that was 25 years ago when I rebuilt the motor so my memory is a little fuzzy,it looks like I will be dropping the pan and pulling the head to get #2 piston and rod out to see what is going on and report back. If alot was not done to that block I would just run it until it blows but I want to see what went wrong.
VCCA #45194
Top
#341476 - 04/28/15 05:53 PM Re: 235 distributors [Re: junkyardjeff]
Don't believe it will KABOOM, based on your descriptions.
You have spoken of a "rattle", not a "knock".
I'm still thinking of a timing issue or a runaway, loose piece of carbon, bouncing on top of a piston.
Time will tell. dance
Top
#341514 - 04/29/15 11:46 AM Re: 235 distributors [Re: bobg1951chevy]
donsbigtrucks Offline
1000
Loc: WI
I think the issue is with the piston/wrist pin. If it was a rod bearing it would have let loose by now after running it for a couple years.
Top
#341525 - 04/29/15 04:02 PM Re: 235 distributors [Re: donsbigtrucks]
A valid point .... no KABOOM on this engine.
Top
#341578 - 04/30/15 03:56 AM Re: 235 distributors [Re: bobg1951chevy]
1000
Loc: Dayton Ohio
I have been hearing the noise for at least 10 years.
VCCA #45194
Top
#341591 - 04/30/15 11:36 AM Re: 235 distributors [Re: junkyardjeff]
1000
Loc: WI
Drive it like you stole it, you'll find the noise.
Top
#341595 - 04/30/15 12:55 PM Re: 235 distributors [Re: donsbigtrucks]
1000
Loc: Dayton Ohio
I need it to make the noise all the time so I can find it so I am going to run it hard.
VCCA #45194
Top
#341774 - 05/02/15 04:11 AM Re: 235 distributors [Re: junkyardjeff]
1000
Loc: Dayton Ohio
Dropping the pan this weekend,the noise got a little louder today and was able to trace to #2 so time for the motor to come apart. I hope its a cracked piston and not a bad rod bearing,if its a bad rod bearing the other motor is going in.
VCCA #45194
Top
#341824 - 05/03/15 03:25 AM Re: 235 distributors [Re: junkyardjeff]
1000
Loc: Dayton Ohio
Its the rod bearings and I think I did not clean the oil passages in the crank good enough and the bearings are scarred and the upper halves are down to copper with only 10,000 miles,crank looks good so I am going to put new bearings in and see how it does.
VCCA #45194
Top
Page 2 of 2 < 1 2
Moderator:  AntiqueMechanic, d2d2
Your Status
Please login to post or reply.* * *
Send My Password
Who's Online
1 Chat Members (Peter_Gariepy), 1 Guest and 32 Spiders or Bots online.
Key: Admin, Global Mod, Mod
Today's Birthdays
32confederate
Helpful Links
Forum Registration
New User Forum
Members Only Forum
Reset Your Password
Kill Your Cookies
VCCA Home
Join the VCCA
Member Photos
My 31' Chevy Show
What is missing?
31' headlight reflectors re-silvered at home
1936 Roadster - S. Africa
Chevy on the Levee
'37 Seat
Forum Stats
15086 Chat Users
79 Forums
50178 Topics
Max Online: 304 @ 06/18/16 10:00 AM
