#336204 03/08/15 08:18 PM
33picup Offline OP
Hi mr moderator iget logged off when switching between different areas of the forum. Is this normal?
George M.
33picup #336224 03/08/15 10:15 PM
No, it's not normal...You usually only get logged off if you haven't posted in a couple of weeks...Give Bill Barker a PM...
kevin47 #336298 03/09/15 12:33 PM
I believe if you switch to the VCCA Homepage and attempt to go into some of its sub-pages (like Member Services), it is a separate 'login' from the Chat Homepage.
If you log on to the Homepage and have the computer keep you logged in, I think you'll be all right.
Another problem might be if your computer cleans up cookies. When the cookies go, so does your automatic login.
