Posts: 34 |
Hi trying to set the initial timing on rebuilt 350 with HEI 300hp. I set at TDC but im unable to turn counter clockwise to 12 degrees before TDC. Can I turn motor clock wise and stop at 12 degrees before TDC. Thanks
Posts: 30,700 Likes: 141
Posts: 30,700 Likes: 141 |
The distributor is one tooth off.
Posts: 388 |
The distributor is one tooth off. Agree with Gene.Dist is one tooth off. If it was 180 off it wouldn't start or run. Get it back at TDC #1 on Compression stroke.Drop it back in with rotor pointing to #1 postion on cap. Good luck. Jim
Posts: 1 |
[quote]Agree with Gene.Dist is one tooth off. If it was 180 off it wouldn't start or run.
Good luck. Jim [/quote]
i also agree! it is just a one tooth off. and is will not run if it's 180. try to get it back again. you will eventually succeed on that good luck!
2 members (modiol, 1 invisible),
63
guests, and
7
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
